e9999 said:Would good material adhere strongly enough to last many years? (Roof can get hot in the desert, could also flex?)
E
If you do a good job of prepping the surface, the glass will hold very well. You'd probably have to grind it off if you wanted to remove it. The flex is also another consideration. Since the roof itself tends to flex, you would want the patch to be able to flex too...at least to some degree. A welded patch would be the best fix I think, but the glass matt would be second best I think. It also would be easy for a DIY job if you didn't have the welding equipment. Either repair will require filler and paint.
Not sure how I would do it myself...the beauty of the nut/washer technique is it's simplicty and low cost. The beauty of the patch technique is that it's permanent and returns the truck to stock appearace.
