When I yank and allow to retract sometimes more than an inch and then yank again. It does not lock. Any ideas why? Both are like this, it seems weird both would do this at the same time.
It's not out of the realm of possibilities they both failed - at the very least, I'd send them off and have them inspected. @reevesci might be able to help you out with this one. . .seem to recall him stating that he has a shop that reworks his seat belts. Worth a shot - especially if it stops your face from imprinting against the windshield =)
Shane
You might consider getting new belts. 30 year old, sun faded nylon will have degraded in strength. OEM was pricey last I checked, if it's even available anymore. Fronts only. Rears are NLA.
There are good aftermarket options in every color imaginable.
Beno found me new one for each side. But all I really had to do was clean out all the dog hair and related crap and the old ones would have resumed normal function
About a year ago.Was this recent? If so I may order a set for my next build..
J
About a year ago.
Has anyone done a write up on aftermarket belts? Where do you get them?
Jason. I went thru GR the other day and thought of chasing you down but I didn't have time for a proper visit (multiple beers) so kept on a movin. .soon I hopeI think the PS is NLA now.. Think Shane bought 2- DS to try and convert the one over.
We need to meet up one day. Not that far apart.
J
My local upholster shop will re-web any seat belt. BUT! he sends them off to a tester in Salt Lake first for liability reasons of course. If a retractable seat belt has been "fired" I believe was the term my guy used or in a crash, 99% of the time they will not pass testing. He said that only a small portion of the belts he sends in for his custom customers rework passes. Jeep, bronco, or many other offroad vehicle belts he almost refuses to send anymore. Said he's only had 2 or 3 sets that have passed out of about 200 sets.. Testing is only 10$ a belt. What he usually does is find a aftermarket replacement and then will replace the webbing to the color needed for the re-build if it is an odd ball color scheme the client is going for.
This is the best way to go unless OEM like @sschruff wanted is the only acceptable end result for you. I believe the PS is still available from Mr Yota, but the DS is not... After looking at the mounting plate with Shane one day, it looks like you can drill the pin, grind the edge and replace the pin and a PS will work on the DS.
@sschruff did you try this or look at this more closely?
J
I'd like to send you a seat belt from a Pig for testing, can you drop me a PM? Not sure how to from the phone...
Same deal if you get over bear lake wayThe beer cooler and shop are always open to fellow MUDDERS. Just give me a little notice when you get some time.
Jason
