Hi everyone, starting my rebuild and upon close inspection I have discovered some issues that were not apparent when the winch was full of gunk and old mud and oil. I found this 1985 8274 and I am doing a complete teardown. Still not decided on powder coat or rattlecan, I really like the Rustoleum HAmmered finish.
Please let me know what your thoughts are on these and whether any of your winches have similar condition issues and how/if you think I should address them.
Thanks!
Outside of lower housing
IMG_4517 by Reed Rothchild, on Flickr
Inside of lower housing
IMG_4518 by Reed Rothchild, on Flickr
Bottom of lower case, do not see the crakcs on the inside of the case.
IMG_4519 by Reed Rothchild, on Flickr
IMG_4520 by Reed Rothchild, on Flickr
Inside of upper housing, see crack behind the large gear.
IMG_4521 by Reed Rothchild, on Flickr
Outside of upper housing, see crack along edge of tab.
IMG_4522 by Reed Rothchild, on Flickr
Also, gear in upper housing has side to side play of about 5mm, can push all the way to touch large gear on housing. Is this normal or does it indicate worn torrington bearings in the housing that would require replacement?
I notice Gigglepin has a shaft replacement kit with bushings and a screw, has anyone used the kit?
Thanks!
