22re check engine light.?
Discussion in '95-older Toyota Truck Tech' started by lispeej, Sep 15, 2008.
  1. lispeej
    lispeej
    994
    1
    Sep 10, 2006
    Minnesota
    I have a 1992 toyota pickup with a 22re. I have a check engine light on. I was told to jump the T1 and TE1 jumpers to read the code. There is no T1.
    Can anyone tell me what the correct jumpers are?
    Thanks.
  2. WristPin
    WristPin
    2,690
    Media:
    9
    96
    Sep 14, 2005
    The NW, Cascade Mountian Range
  3. WristPin
    WristPin
    2,690
    Media:
    9
    96
    Sep 14, 2005
  4. lispeej
    lispeej
    994
    1
    Sep 10, 2006
    Minnesota
    Thanks....
    I will recheck tomorrow.
  5. KLF
    KLF Frame waxer SILVER Star
    6,302
    524
    Apr 5, 2003
    Southern NH
  6. lispeej
    lispeej
    994
    1
    Sep 10, 2006
    Minnesota
  7. lispeej
    lispeej
    994
    1
    Sep 10, 2006
    Minnesota
    Code: 21
    So I get a code 21.
    [SIZE=-1][/SIZE]
    [SIZE=-1]21[/SIZE]
    [SIZE=-1]OXYGEN SENSOR SIGNAL/OXYGEN SENSOR HEATER SIGNAL[/SIZE] [SIZE=-1]OPEN OR SHORT IN OXYGEN SENSOR OR OXYGEN SENSOR SIGNAL[/SIZE]
    What does that mean?
    Bad O2 sensor?
  8. Hilux
    Hilux
    2,158
    3
    Apr 2, 2008
    Nashville Tn.
    ....if I was a betting man....
    IIRC a lot of codes have a, "short circuit in terminal "T" when ac switch ON or IDL point off."
    and if that's the case the throttle body needs to be checked.
    you don't have have so I'd bet it's isolated to the O2 sensor.
  9. WristPin
    WristPin
    2,690
    Media:
    9
    96
    Sep 14, 2005
    replace it with a NTK or bosch brand O2 sensor only.
  10. lispeej
    lispeej
    994
    1
    Sep 10, 2006
    Minnesota
    Cool. Atleast we're getting somewhere......hopefully.
    I'll try the O2 sensor and see how that goes.:cool:
  11. pappy
    pappy photosynthesizing Moderator
    7,934
    Media:
    78
    218
    Oct 7, 2003
    Palm trees and cool streams
    I will toss in Denso (OEM) too. You might be able to pick up a Denso at oxygensensors.com. They have them for many applications.
    NTK is good. My luck with Bosch has not been good.
  12. WristPin
    WristPin
    2,690
    Media:
    9
    96
    Sep 14, 2005
    i have used bosch in almost all the cars and trucks i work on. only time they dont werk is if i use the universal one and mix up the heater and sensor wires....
    but you are right pappy NTK is better anyway. same with denso. gotta go with the high quality jap stuff anyway :D
  13. lispeej
    lispeej
    994
    1
    Sep 10, 2006
    Minnesota
    I went to the local auto store today, and they couldn't find an O2 sensor in stock. They said they'd have to special order it. It was a bosch. I was shocked! Olreily's auto didn't carry it. These things are not cheap...LOL.
    I'm curious, this might be a dumb question,,,,but would this potentially take care of my bogging and slow acceleration issue?
  14. pappy
    7,934
    Media:
    78
    218
    Oct 7, 2003
    It could. I've also had failed OX sensors cause a rough, erratic idle. It should also improve your gas mileage.
  15. lispeej
    lispeej
    994
    1
    Sep 10, 2006
    Minnesota
