It's weird you had problems with it. Always worked fine for me oh well. Glad to hear it!Pretty good. Found a rebuilt OEM carb and she runs like a champ.
Nice find! Although, it's been too wet and rainy here in PDX to get under the hood and see if it is, in fact, the heater control valve. I'm in the process of trying to clear out garage space so that I have a dry place to work again. Hopefully I'll be able to check the valve in the next month or so, so that I can cross that issue off the list.Probably the number one issue with your heater is the control valve. They're no longer available from anyone, but the later model truck's (84-88) will work with some creative additions. I found this on of all places Reddit, just looking at the pic was enough explanation.
I've had my '80 for several years and couldn't tell you if the heater works either. I'm in AZ...
The PO of this truck did what ca. Be described as "jump-starting" the AC, bypassing the relay and energizing the compressor coil directly. Again, not sure it works.
Search around for a 5-speed conversion write-up, it doesn't require much more body mods than just a hammer to the underside of the floor to clear it. I would agree getting rid of that awful 4-speed would be high on the list if you drive it a lot. If yours is sloppy too, even new bushings for the shifter won't help very much.
Your door panels look to be pretty good, why change them out?
'79s also did not have the welded front axle truss. First year for that was '80.
Mid 1980 model year. I had a September 1979 built 1980 RN47 and it did not have a trussed front housing.
Early '80 RN37 siting right outside for my reference. No matter.
What month? I don't remember the changeover
The group I worked for used ADP, later CDK. Over the decades I did a lots outside parts inventories in stores that used Reynolds and UCS. UCS was nasty. We called them Useless Computer Systems
When did AmToy stop using microfiche? I seem to recall you looking up parts for me on that system back in the day. Maybe it was another dealer before I moved to NM.I found my 40-year-old microfiche this morning.
