Jason brewer
Jasonbrew
Help If you can,
I have read almost every post and tech guide on the forum... from coolerman to others tech write ups. I haven't seen anyway to test the igniter with a multimeter or such.
Here is the deal, putting my project back together and for a week now I am pulling my hair out. I bought this totally disassembled. I have 3 distributors, 2 igniters (one looks bad, the other new), and 2 coils. The PO had an MSD blaster 2 coil with a mallory distributor and tallest resister. I have no idea if he used the igniter or not.
Testing the coil with he multimeter per FSM specs out perfect. I have 3 good coils. Distributor set to TDC per FSM. Check. I have interchanged both the OEM 78 and the mallory trying to get anything to work. With & without the tallest resistor. With & without the igniter.
NO FIRE no matter what with either distributor. OEM or Mallery. *I can get the mallory to spark without the igniter. it is a Magnetic Brakeless Distributor.
When I check the volts with key on at the + of the coil I get between 5-6v with hooked to the igniter. Is this normal? The - is around 1v. Its seems like when I hook either igniter up there is a major voltage drop on the coil... I'm stuck. any help would be awesome.
