Figured I would add a review of my Goodridge lines here and maybe we can get thread kicked up to the FAQ.
I installed the Goodridge G-Stop Lines part number 2-21127 in early 2009 on my 2000 LC. The kit has 2" longer lines for chassis to diff in rear and the fronts. The lines at rear calipers are standard length.
I was not happy with the routing caused by fitting at caliper, so sent fronts back to Goodridge and had them change fitting. Since they cut old fitting off, front line ended up being about an inch longer than stock. They did it for free, so was only out shipping to them. Not sure why it had this fitting as it does not makes sense, Slee earlier in this thread mentions that there are different hose configuration, so maybe on another year it works fine. Don't know if they have changed front lines since then.
Would recommend these lines as they improved pedal feel and are more rugged. Have had them on for over a year now.
First photo shows lines right out of the box. Second photo compares stock front line with Goodridge line. (The factory line fitting at the caliper has an indexing pin that goes into a hole in caliper, this keep banjo fitting from turning. Neither Goodridge line nor the modified line have this. Don't know how important it is.)
Last photo shows Goodridge front before and after modification. I had asked Goodridge to turn ferrule bracket (in middle of line) around when they changed fitting. But they forgot, so I moved it to other side of mount as shown.
Little update for everyone.
I have a brake job coming up soon and have been doing a lot of research. One of the areas that have been on my to-do list for a while is extended stainless brake lines. I decided to order the kit above through http://www.buybrakes.com/. I took a gamble and placed the order and figured I would do what Skidoo did and send them in to get the fittings adjusted if needed.
I placed my order yesterday and received a call today that they were not in stock. Turns out the extended lines are almost always made to order and not kept in stock. No big deal I am not in a hurry.
So while on the phone with the sales person, I mentioned having the fitting changed since they were being made to order and there had been some fitting issues with them in the past. Both the sales person at Buybrakes and at Goodridge have been more than willing to build them how I/we need. I forwarded them this thread with the pictures and a picture of the OEM fittings on my truck. Everything is being made as I need with no hassle.
So, if you are looking to do extended braided stainless lines, Goodridge is still making them. Just look under your rig first and verify the fitting at the caliper. If it is the same as mine and Skidoo as pictured here, might want to contact Goodridge and just have them make you a set from the start how you want. I also have had nothing but a great experience working with buybrakes.com and would order from them again based on this experience.
Hope this helps any one looking for a solution.
