Ok, I have an equally as ignorant question as my original post.
Regarding lifts....other than being able to add larger tires and allow for more flex...there are no other benefits, correct?? (Obviously, there are the negatives, worse gas mileage, worse handling, etc)
Regardless off how high you jack up your vehicle up, your axles (rear sway bar) will always restrain you (regarding clearance), so with the increased height from the lift you can go from say 35" tires to "37," which gives you 2" of gross lift but only 1 inch of axle lift....correct??
I have been considering a lift but I just bought 285/75 duratracs (about 3 weeks ago) so it will be a long time before I upgrade tires. Looking at the "flex" part of it, other than pulling the front sway bar bolt, there is most likely nothing more I will invest into getting greater flex-meaning long travel shocks, etc.
I went "Rock-Crawling" for the first time, (not many rocks around here) and loved it. My lowest clearance areas appeared to be the rear sway bar and the spare-tire. (Next time spare will be in the trunk).
Lastly, I am assuming sliders will be the lowest point, by design, on a vehicle.
So, help me out...will a lift do anything for clearance if I keep my tires??
Thanks In Advance!
