Old 07-14-08, 09:58 PM   #1
romey's Avatar
and yet another rear storage box idea...
so, after some searching and getting ideas on mud I decided to do my first project on the 80, the rear storage box! So same idea as most, a flat surface you can sleep on with drawers underneath. But it had to be based on a few things:
- has to be simple
- has to be somewhat lightweight w/o sacrificing integrity
- has to be removable / disassemble-able (so I don’t have to drill holes in the body and make it permanent)
- and it has to be something different, have removable drawers that can be changed and not necessarily wodden boxes on rails..
so I went to wallmart and local hardware stores to get some ideas….i’ve seen lots of Rubbermaid storage boxes so I started with those and did some measurements…b/c of the depth of the trunk I figure it best to have 2 boxes lengthwise…non of the rubbermaids would work but I found these drawer style storage bins…
I measured and 2 back to back would fit perfectly, then I figured, why not flip one backwards so it can be used inside when the seats were folded down…then this got me thinking, I can extend the platform over this drawer and make a trap door to get access to it, so cool.
1991 HDJ81 VX ltd - bone stock
anyone run str8/waste veggy oil on their hdj81? post up!
http://forum.ih8mud.com/ca-bc-coasta...ml#post3373049
romey is offline   Reply With Quote
Old 07-14-08, 10:01 PM   #2
romey's Avatar
In the end, I decided to buy 4 of these bins and have 2 rows and make a wooden drawer right down the middle to store tools and stuff. The bins may seem a little weak but I figure they’re in there snug and I don’t think they’ll move around much. And as far as items stored in it are concerned, I figured it’d be mostly clothes, camping gear, and food for my planned roadtrips…soon to be mini expeditions hopefully… But, worse comes to worse, one ruff and tuff Rubbermaid bin with heavier duty lid will fit too with the white bin. (but 2 together wont) so I have the luxury of swapping bins depending on needs…. Or take them out and throw in a long duffle bag.
Materials:
-5/8” spruce plywood (I didn’t think 3/4” was necessary)
-1/4” peg board (to try and save some weight)
-hinges,screws,nails
-carpet/contact cement/staples/gun (i looked everywhere for darker grey but all i could find was black and this lighter stuff)
So, I decided to make 2 boxes to store the bins and have them support the flat platform to sleep on (with the long drawer sandwiched b/w, it would provide adequate support to sleep on). Up top, I figured I’d make a swing down cover that extends the sleep area but have it so that it has a lid that can give me access to items inside/under the storage area (most have made drawers that pull backwards, I just figured I’d just pack things I’d need inside the vehicle to be stored further in in-case I need to get at them inside the truck w/o having to exit the vehicle and open doors….
Old 07-14-08, 10:04 PM   #3
romey's Avatar
So with boxes and drawers made, I figured I’d make the top platform in 2 pieces joined by a piano hinge so that can be removed too. The 2 forward foldable boxes are then hinged to part of the top platform but this little piece is also removable (but snatch lachable to the main platform for stability). So all in all I have 2 separate top boxes that are joined to what’s part of the top platform that makes it all removable. Undo the snatch latch, remove the top boxes, remove the top platform, remove each drawer box and you’re back to the large empty trunk space.
After carpeting, everything became snugger and more secure. I used little blocks on the underside of the platform to keep it from shifting laterally. With the top boxes folded, I decided to cut holes on the top platform and run a strap around the belly of the boxes (around all drawers) to lay over the lip of the top boxes to help secure them down further. Because everything is butted up against each other snuggly, there is virtually no movement. The carpet makes for some nice friction to keep things from sliding, the hinges and latches act as extra secure points and the strap connects the entire storage area and snugs them all together.
I’ve driven with the boxes laid flat and folded up and there isn’t one rattle or shifing of things. This afternoon I had to avoid a bunch of cars that braked suddenly and pulled a quick left turn and right, very suddently, and the boxes didn’t budge! I guess the true test will be over some tough terrain but I doubt I’d be taking the truck through any of this type of terrain anytime soon…but I’m confident that things will stay down b/c of the weight of it all and the fact that there’s no room for any wiggle,…only on a roll over will there be any realy movement of stuff.
I took a little nap over the box and it felt very secure.
Old 07-14-08, 10:08 PM   #4
romey's Avatar
Btw, this only works if you are 5’8” or shorter! Fits me and the wife just right, plus we don’t sleep with our legs fully extended, more on a fetal position anyway, so it’s nice and cozy inside. I might make another piece of wood to go over the small gap in between or just leave it and just rely on whatever sleep mat I lay ontop of it all, nothing major. The gaps on the sides allows for room for shoes too. Curtains are up next….
Old 07-14-08, 10:11 PM   #5
romey's Avatar
all done. just a couple things i might add later on...
the long drawer actually slides okay with wood over carpet, but i'll probably duct tape the bottom to make it smoother for less friction.
i thought about painting some parts but opted out of it for fear of paint releasing lead or other chemicals. the contact cement smell is all but gone.
Old 07-14-08, 10:16 PM   #6
romey's Avatar
didn't attach these right in the beginning...
Old 07-14-08, 10:26 PM   #7
Tricking my truck
bowyer2002's Avatar
Nice simple design - BTW does anyone post all the dimetnions for building these since they seem so popular even though there are several variations? It would be helpful and gain Ideas to fit particular needs - good job!
97' LX450 (WIFE'S) OEM CUPHOLDER, PHH, POWER ANTENNA FIXED & RECENT FRONT AXLE REBUILD!
01' TACOMA DBL CAB, LIFT, ARB, ARE SHELL, HI-LIFT, SLIDERS, WINCH, ETC.
ORDERED & WAITING ON SNORKEL.....
bowyer2002 is offline   Reply With Quote
Old 07-14-08, 10:33 PM   #8
romey's Avatar
box-o-bots, transform!
the fold down boxes also act as storage upside down. gonna find some spider bungee cords to go over it to keep things from flying out, and i might add some latch points on the top plat form to have different tie down options for certain things.
the only thing i wished i could have taken advantage of are the stock latches on the floor under the carpet, it just so happens that they're sit directly under the box frame! doh!
if i could do it over again, i'd try and fit 3 of the same bins (or narrower bins) on the back and go past the back of the wheel well, and 2 bins near the front doing away with the long drawer, i think...
the cool thing with the bins is that they're stackable, so if i were to do a road trip to visit family/friends i can just pack my stuff in the drawers nice and flat and pull them out individually and stack them in the room i'm staying to use as a dresser sorta...
Old 07-14-08, 10:41 PM   #9
blackisback's Avatar
good job, those look really nice. I like how versatile they are and i love the fact that you can access storage in all positions at any time. well done.
96 Lexus Landcriser (LX450)
Locked and loaded, Black on Tan, 8 seater, dual batteries, 18" Altera Rims with 32" Falken rubbers. Infinity Amp, MB quart speakers, pioneer premier 12" sub. Purple interior lights and Blacked out windows.
blackisback is offline   Reply With Quote
Old 07-14-08, 10:43 PM   #10
romey's Avatar
oh yeah,i spaced the fold down boxes so i could fold one half down and use as longer area to store bigger items, and still have a 3rd person sit.
and i just had another idea, if i wanted to do away with the fold down boxes, i could just make up those long flat thin pieces in the same way w/o hinges, just to cover that small area...say so i can put a TV on the back, but then again, i could just fold everything down anyway...just an option.
Old 07-14-08, 11:05 PM   #11
romey's Avatar
thanks guys. if anyone's interested i can easily take measurements and post 'em. the cool thing with this is you can choose whatever bin you want to use and just make the holding box accordingly. you can go taller or shorter. i think i saved weight by not making drawers and using the bins. i can further cut weight by cutting cheese holes on the sides of the holding boxes a la jamisobe, or just jigsaw squares out carefully w/o sacrificing strength... aluminum would be saweet tho.
just a note, one holding box by itself w/o anything inside is weak, the structure actually relies on all boxes stacked together side by side to stay rigid enough to support my weight.
Old 07-14-08, 11:06 PM   #12
sprocket3's Avatar
That looks great. I came up with a different design as well but i'm such a bad carpenter that it's not going to get published. There are some good wood mechanics on this forum.
-2000 UZJ100
-1997 LX450
sprocket3 is offline   Reply With Quote
Old 07-14-08, 11:14 PM   #13
landcruisers4ever's Avatar
looks good man, great design
1997 lx450 "Alexus" 3 OME lift, ARB winch bumper, safari snorkle, T-max competition 9000 winch, custom rear storage system and factory lockers X3
2000 lx470
1976 FJ40 current project
2008 Sequoia
1988 FJ62(hurricane)
1977 FJ40(sold)
landcruisers4ever is offline   Reply With Quote
Old 07-14-08, 11:19 PM   #14
romey's Avatar
do share the idea! the last time i cut wood was in elementary, so i say go for it. these are just straight lines, the hard parts is just measurements. i actually used the local hardware store to do most of the cutting (just square/rectangular shapes), i got 3 free cuts with the 4x8 wood and the guy did extra for free or charged just a buck each cut...place was called Rona, the canadian Lowes/Home depot. the rest i jigsawed or circular sawed..
Old 07-14-08, 11:25 PM   #15
chitown40's Avatar
TLCA# 14424
Nice job. I would consider making the sleeping platform (front boxes) removable as you might find over time that you need the space with the rear seats upright.
Anyway, good job thinking outside the box (no pun intended) on your design.
1997 FZJ80 CE - Locked, CDL, ARB, 315 MTRs, OME Heavies, Custom sliders, Custom drawers, T-Max 10K, York OBA System
TLCA #14424
chitown40 is offline   Reply With Quote
Old 07-14-08, 11:25 PM   #16
jamisobe's Avatar
Looks very good and you whipped it together pretty fast. Where did you come in on final weight?
I checked out one of those mattress topper pads at Costco last week. I may switch to the topper some day to save space if it ever becomes an issue. Its not an issue now so I'm not pressed.
95 FZJ80 custom headers & 3" flowmaster exhaust, 4" OME lift (with CC bushings, x br lines, adj panhards, heavier dropped sways), ARB lockers, 35" Toyo M/Ts, dual dry cell batteries, 2300 watt inverter, speedo corrected, & Kaymar w/carrier Next: ???
jamisobe is offline   Reply With Quote
Old 07-15-08, 06:34 AM   #17
romey's Avatar
yup, they're definitely removable (see post #2 and #6), that's why i separated the attachment of the fold down boxes to another piece that latches on to the main platform.
and thanks!
Old 07-15-08, 06:44 AM   #18
romey's Avatar
thanks, i think total time, maybe a couple weekends, but having done it once already, i'm sure one weekend will do if you gather all your materials all at once (it was going back and forth to the stores and deciding which hinges, carpet, wood to use and the measurements that took extra time) carpeting was the messiest and trickiest, it's like giftwrapping!
im very curious about final weight too. i'll see about using just a simple bathroom scale to add up the weight. i can't see it weighing more than 100lbs...but will check. i figure it still weights less than one adult and i know with 5 adults and luggage the truck still does very well on mileage.
Old 07-15-08, 08:39 AM   #19
jamisobe's Avatar
I made many a trips back and forth to Lowes standing around looking at hardware. The clerks have got to know my face and eventually stopped asking "can help you find something?".
Yours looks light compared to what it could be. I used a digital bathroom scale for weighing.
Old 07-15-08, 08:57 AM   #20
I-HEART-DIRT
Bluetribal's Avatar
Has to be simple! - Ha, that looks more like a Transformer than Simple....
No but nice, job and with as much thought as you put into it I am sure it will fit your needs perfectly!
Man, I can't wait to build mine! Mine too will be Transformer like in that I only want half a box but a full platform bed.... I have some ideas cooking up in my pea brain that I can't wait to work out in true form....
Mark
96' LC - 285 Cooper STT's | Slee Skid Plate | Eclipse Speakers | JD Bulbs | Rear Cargo Light | Durabaked | Visor Fix
| Hanna Bumper | CDL Switch
Check out SoCal 80's
Bluetribal is offline   Reply With Quote
Old 07-15-08, 09:25 AM   #21
romey's Avatar
lol, it's a transformer allright! i've got extra carpet and might cut out the autobot logo out of it and stick it on the middle drawer just for sh*ts and giggles.
do it up! good luck with yours, it's a tonne of fun! my was like, "sheeesh, you and your box and forums, .... arggghhh!"
Old 07-15-08, 09:27 AM   #22
romey's Avatar
i hear ya. i still have to disassemble it all to vacuum all the wood bits and dust underneath and get ready for camping this weekend, so i'll try and weigh the pieces then..
Old 07-15-08, 11:31 AM   #23
WHARRGARBL
ed97fzj80's Avatar
TLCA# 15645
Maybe I missed it in the description, but how is the assembly secured to the floor?
ed97fzj80 is offline   Reply With Quote
Old 07-15-08, 11:35 AM   #24
pint's Avatar
TLCA# 17493
Nice work! I really like the design.
2000 UZJ100, OME 865, OME T-bars, Slee Diff Drop, Slee SliderSteps, TJM T3, PowerStop Cross Drilled & Slotted Rotors, 295 Terra Grapplers
M101 Trailer - Sold
1993 Bontrager Race Lite MTB
pint is online now   Reply With Quote
Old 07-15-08, 12:49 PM   #25
romey's Avatar
there's none, the idea was to have it removable but snug when assembled...security did cross my mind when building, but so far with sharp turns and hitting bumps, there's not much movement goin on. like i said earlier, hard wheeling will challenge the design and certainly a roll over will move things around. i really wanted to utilize the stock latches and have straps go around the whole thing but the frame sits on the latches... what i could do (and i already considerd this before, and might still do), is cut a notch just over the latches to make room for a D-ring or hook that'll hook on to a latch and i can tie the whole thing down even more..with regular driving, the weight of things is enough to hold it down. with the seats back up and everything tied down and latched, there's nowhere else for the box to move, except up in a roll over. i can still use a net (similar to the one in a differnet thread about a nylon back cage to keep stuff from jumpin out, i can use the same netting and cover the whole box down and use a latch, or drill new holes for a new latch location...if i had to.
Old 07-15-08, 01:50 PM   #26
sseaman's Avatar
nice work, another interesting variation. you can always remove the small boxes and lay down the middle seats for more leg room, a good cushion and you really wont feel the small difference in the platform
