2ndGenToyotaFan
Moderator
- Joined
- Jan 8, 2006
- Threads
- 264
- Messages
- 9,803
- Location
- Ashland, OR
- Website
- www.jeffersonstatecruisers.com
Well...... my rear E locker decided that it wanted to start leaking around the pinion. I checked the pinion for play up and down and in and out, and it was all tight, so the seal must have gone bad.
Side note: If you have a stock differential with a crush sleave, and you have play in the pinion up and down and in and out, and it's leaking, you might get away with just tightening up the large nut holding the drive flange on. If you do this you want to un-stake the nut, and tighten it up till it's snug plus just a little bit, but make sure the pinion still turns freely once it's tight.
I set up my E Locker gears, and installed a solid collar at the time, so that wasn't an option for me, nor was there any play in mine causing the leak.
Step one, remove drive shaft from the drive flange.
Step two, un-stake the locknut using a small sharp punch.
Step three, remove the nut, and the flange.
Step four, remove old seal, I like to use a sharp screwdriver...
Step five, grease up new seal, and fill in the backside where the little spring is so it doesn't pop out while you're knocking it in... If you are anywhere near a Toyota Dealer, get a Toyota seal, this one is $8!!! The aftermarket ones are $15 in town....
Step six... install seal with a seal driver, or a block of wood... Don't mess it up or you'll be going back to the store...
Step seven... Clean up Drive flange, check it for a groove where the seal rides. If the groove is too deep, then no seal in the world is going to fix it. Then reinstall...
Step eight... Tighten lock nut up, and re-stake. If I am reusing the lock nut, I usually go a little past where it was staked before, because the bearings have worn in some since it was last staked, unless you know differently. Whatever you do, make sure the pinion is tight, but that it also turns easily.
Step nine, reattach drive shaft.
And that, is the wrong way to do it...
The right way involves getting a new crush sleeve, and pulling the differential apart so you can properly test all the bearing preloads.... But who wants to do that, it's wheeling season again!!!
