I've done the measurements for the canvas and I'm getting ready to build me an OEM style soft top.
I have decided against using factory bows as I have a perfectly good set of kayline folding ones on it already. They look just like this:
Thanks to muddonkey for the pic
I'm going to continue to utilise the tube framing above the doors and the pillar because it works and I already have the hardware.
What I don't like about the kayline tops is they make the Gecko look like a jeep due to the funny windows and the slanting back. My idea is to maybe extend the rear bow so that back end of the soft top is directly in line with the tailgate rather than slanting.
I have a few options to allow me to do this extension, but the one I'm leaning most towards is making the rear bow length-adjustable with a spring-loaded stud like you sometimes see on the legs of those cheapie folding tables.
Like this:
If the spring-loaded stud system turns out to be too much of a technical challenge, I may have slum it and use a thumbscrew system like you find on some collapsible tent poles.
Like this:
It has to be adjustable for two reasons:
1. If I just leave at its current length I'll end up with what looks like a green canvas TJ jeep top with cool side windows
2. If I lengthen it and weld the extension into place, then it won't clear the jerrycans on the back
So the OEM-style top won't have the middle bow unless I somehow graft one onto it, but if it all works as planned, I'll have found the holy grail... a way to mate an OEM style soft top to Kayline bows.
I guess before I get started on chopping up my rear bow, I should ask...
Has anyone successfully done this?
Like this:
Like this:
