- Joined
- Jul 5, 2010
- Threads
- 13
- Messages
- 310
I'm trying to resurrect a '69 with a 1F motor and cannot get it to run well. I'm getting zero vacuum at idle, as measured from the port at the base of the carb, and have very poor throttle response off idle. Anything more than just very gentle use of the throttle causes it to want to stall out. With the engine well warmed up it gets a little better, but nothing that I would consider safe to drive.
The carburetor I currently have on it is a trollhole-style amazon special, but I have also tried a genuine trollhole that was on it previously but needed a lot of going through to clean and verify that everything was working. I followed PinHead's videos on youtube and had everything working pretty well except for the power valve being a little sticky. But I've also tried a '69-'71 2bbl genuine Aisin carb set up according to the Haynes manual for all of the adjustment screws. Nothing runs well but at least with the two later style carbs I can get them to idle off choke.
I have rebuilt the mechanical fuel pump and fuel stays pretty close to exactly halfway in the sight window.
I have verified timing with two different timing lights. Both have the timing pointer at the top edge of the BB, so roughly 8 degrees advanced compared to the stock 7. My altitude is ~2700ft, desert climate.
I have verified that spark is good for all cylinders with at least 3/8" spark according to my cheapo spark gauge.
Compression is 75/125/122/118/122/122. A little low for cylinder #1, but I would think it could still be made to run okay. I did a motor flush and an oil change but the numbers didn't improve.
I've tried two different sets of spark plugs and wires and two different ignition coils. (I'm blessed to have a second FJ40 to borrow parts from but the other 40 is even further from finished than this one.)
The distributor is a mechanical advance and appears to be functioning correctly, according to the timing light.
I suspect there is a vacuum leak somewhere, but I just can't find it. It would need to be a pretty severe vacuum leak to have show zero vacuum at idle according to the vacuum gauge, right? I've sprayed everywhere on the top side of the engine with both carb cleaner and starter fluid trying to find the leak.
The PCV valve is a new, Toyota valve, along with the grommet. I do get strong vacuum at the hose between the PCV and the carb riser. If I disconnect the hose from the top of the PCV with the engine running the engine dies immediately. If I plug the hose with my thumb I can feel a strong vacuum from the carb riser, but the vacuum gauge still reads zero until I rev the engine a little. Once I have the engine revved throttle response improves dramatically.
I have adjusted all the valves and the seals for the valve cover, the base gasket and all 4 screw gaskets, are new and don't appear to be leaking.
This did originally have a vacuum-assist transfer case but has been converted to 3-on-the-floor with a floor shift transfer case. I'm not sure where vacuum would have come from originally to power the transfer case but I assume it would have come from one of the three ports that I can see plugged on the intake manifold.
I suspect the truck does have a rear main seal leak. Could that be a significant source of vacuum leak? Not sure how I could verify that without taking the transmission off. Is there an easier way to identify a vacuum leak away from the head? Unfortunately I don't have access to a smoke machine, but if that's the only way I'll get one.
I suspect whatever my issue is will be easy to fix, but I am having a heck of a time trying to identify it. I'm open to suggestions. I've been beating my head against the wall at this for over a month now. I still need to try searching for the vacuum leak using an unlit propane torch but previously the backfiring made that a little scary. I have things tuned as well as possible (lean drop method, idle in the 650 range but not terribly steady) given the circumstances so it's probably safe enough to do now.
Does this sound like a carb issue to you, a vacuum leak issue, or something else entirely? Please help.
