- Joined
- Jul 5, 2010
- Threads
- 13
- Messages
- 310
- Thread starter
- #41
Idle screw is currently 2.5 turns out, although I feel it runs pretty similar from 2-4 turns out. I did set it using the lean drop method. Timing is bang on the BB, so 7 degrees. I jumped back and forth between distributor and carb when I tuned it last. I could try advancing the timing some but I figured it was best to tune things by the book until I got it running reliably.
I feel like it has to be something other than the carburetor, distributor, coil, plugs/wires or PCV valve, since I've tried multiple of each of those and the symptoms don't really change. My best guess is a vacuum leak, but I can't find it. I've tried using carb cleaner, starting fluid and an unlit propane torch. I've only really checked around the engine bay. I worry that maybe my rear main seal is bad enough that it is letting air in. I'm not sure if that's a thing on these engines, but I've had the rear main seal go out on my Audi and the vacuum leak it caused really messed with how it ran. I do have an oil leak, which I assume is my rear main seal.
I'll try again to identify if there is a vacuum leak in the engine bay using the short bursts of starter fluid method. I was maybe a little too liberal with my application of starter fluid earlier. I'll also check how it runs if I introduce an intentional vacuum leak.
