From a power standpoint, I have the following numbers for 2f and 3fe: 135hp/210ft-lbs vs 155hp/220ft-lbs. How does the 2fe fit in here?
I seem to recall that the 2fe got a compression bump. My curiosity I guess is drivability/power. With luck, my club member will get his going here shortly. I just recall LOTS of issues with bad heads, accessories, and wiring.
I don't have a fuel tank yet but I will probably end up with something custom in the very butt end. I could possibly do something very similar to how I did my FJ55 tank with stock Camaro fuel pump assembly... I've never seen a 3fe fuel pump.
forum.ih8mud.com
For some reason, I think finding a complete 3FE might be a bit easier to find that a compete big block cadyI found the latter for dirt cheap.
My transfer case expert told me the 34mm cases are not the best choice for 4:1 gears. His claim was machining was thin in a few areas.
Oddly, I've got an H42/split case sitting on my floor right now that I was considering for this 40. But I have a club member has a more immediate need for it
Sadly, as I mentioned, this is a very back burner project so I'm not pushing real hard on acquiring a drivetrain yet. Rain/snow are coming shortly and I'm garageless so next 4-5 months will be no 'real' fab.
Plus, I still have a drivetrain to stab before I get dumped on![]()
