Would You???
If you were doing a complete modrestoration would you relocate your gas tank out of the cabin? On a whim last night when I was working on the truck I decided to cut out the fuel nozzel housing and relocate it to the back of the truck (rear quarter pannel back). We're going to weld it up on Monday....
I think I'm going to find a GM gas tank of sorts and mount it between the rear frame cross members under the tub bed. I just feel a little uncomfortable knowing that a fuel tank is below my passanger.
Thoughts, suggestions, etc are appreciated.
Best,
UNO
the stock location is the best spot .you will find that out in the rocks.back in the day when cruisers were first shipped to the states consumer reports put out that land cruiser gas tanks were unsafe.the following year or whenever they made a apology for there mistake.leave it stock you will thank toyota later:cheers:
there's how many 100 of thousands of these around the world? best is stock
I'm on the fence on this one. Under the seat is well protected inside the frame rail and in the rear would be under the kids if you have any (I don't). I've never seen a 40 have an issue with a tank puncture, but I have seen it on a heep. It would be nice to have a little extra dry storage however. In some ways it might be better to build an infloor storage in the back like a Honda Ridgeline if it's lifted and you have room.
Make sure it's protected!
If you decide to mount it out back between the frame rails, I found that a tank from a Chebby S-10 Blazer fits perfectly, well it fits a 55, so it *may fit a 40 too. It's a 20 gal tank & I added a body lift & a protection cage for it. You'll need to modify the sender as it's setup for F.I.
pretty sweet mod but im with everyone else on this. the safest place is probably going to be in the cab. the body tub door jams protect the tank from being smooshed in an accident. it is ectremely thick metal there and the door jam goes around the gas tank. i would think you would have to be in such a great impact that you would be dead before the tank would ever be unsafe under the passanger.
theres alot of reasons but I think it looks cool. just no smoking in the cab. haha
My opinion is get a 79 if you want the tank on the outside. That's what I did. :). Some people actually like the gas tank on the inside since you get more clearance.
I've lost count of the number of severely wrecked '40s I've parted out. And severely rusted hulks I've disassembled. Or rigs which fell into both catagories. I have never seen a tank damaged by anything except time and rust. Much less actualy breeched. I have never heard mention in any of the internet forums any tale of an in-cab tank in a '40 being a problem (other than being stinky when they were rusted out and leaking). And I've been participating in these forums since most of them began. ;)
The factory design is a good one. It also enjoys a better location in terms of effectt on center of gravity and spliting the load between the front and rear suspension than a tank located behind tha rear axle. Also more protected from rocks. And it offsets the driver's weight better in that location.
Really no reason to forsake it.
If you want to add an auxillary tank, then the area behind the axle is the first choice for many. Myself and a couple of other guys here are in the proccess of doing installs of tanks ahead of the rear axle. With the rearward relocation that we do on all of our '40s, the SOAs and the 2 inch body lift that we have on these rigs we have room for maybe as much as a 25-30 gallon tank. I haven't looked at it yet myself, but one of the guys has an S10 tank that he says will fit very easily ahead of the rear axle.
Mark...
After careful consideration and your imput, I've decided not to relocate the fuel tank. Now I just have to tap weld the fuel nozzel holder back into its place. Thanks for the reccomendations. I just wish I would have posted this request prior to cutting away. Lesson learned, I guess.
