This might be sound obvious but have you checked your fuel flow where it enters the carb and ensured you do not have a partially clogged fuel filter - or a second one someplace you did not know about?
Two fuel filters….one of the old style glass housing that is new as of 1 year or less…and another one I put closer to the carb to see if fuel was making it up to the carb. I wonder if that could be the issue?? Neither is clogged though…and cold starts start up with no issue.This might be sound obvious but have you checked your fuel flow where it enters the carb and ensured you do not have a partially clogged fuel filter - or a second one someplace you did not know about?
A partially clogged filter can slow fuel flow and then as the vehicle sits, enough fuel can get through to then allow a start again. Then higher rpms pushing (or pulling) fuel through a filter allows a vehicle to run with little to no issue.Two fuel filters….one of the old style glass housing that is new as of 1 year or less…and another one I put closer to the carb to see if fuel was making it up to the carb. I wonder if that could be the issue?? Neither is clogged though…and cold starts start up with no issue.
