Wiper/washer function
Dover, DE
With the washer function on the wiper switch. Should the washer also work while wipers are operating?
Mine does not.
EDIT:
I am sorry, I misread your question. Yes, while my blades are operating I can spray some washer fluid.
Unless you use the washers frequently, the switch can get gunky and the squirters won't squirt. I have to turn my knob firmly to the right to get it to squirt (and yes, it should/will squirt with or without the wipers operating).
This is good personal advise as well.
No squirter problems here.
Switch is relatively new OEM, 6 months or so. I thought that is how it should work. Sprays like hell with wipers off. With them on, at either speed, nothing.
I will check on wiring. Thanks folks!
YES !
both circuits are independent of each other on all 1, 2 and 3 pull / positions
land cruiser wiper switches ............
and YES , TOYOTA did make a single pull / 1 speed only wiper switch ,
from 1977 to 1984 . it was popular in the Saudi Spec. Region mainly .,
and also in Military spec. and police spec. 40 and 55 models ..
it has the same washer rotate function as any other push pull wiper switch
i see this might be your 1974 Godzilla ?
in fact ALL your FJ40 's take the same wiper switch ...........right ?
im gonna take a leap here and make 2 possible cause theory's : 🤔
- #1 you have installed your top terminals connector backwards , by mistake , its easy to do , on a old 40+ year old whits NON-UV rated connector housing , thats broken down a bit from UV rays ..............
- #2 your front rotate spring and retainer stand off have come apart during initial install , or were off before u bought switch , i have sourced more then one 71-84 wiper switch from my dealer that were like this new in the parts
bubble wrap pouch ,
they get knocked off during shipping or stepped on by careless parts staff ?
see pics below to see what i refer to .............:)
- take note: how the rotate spring hooks onto the front switch stand off
and the bottom hooks of the rotate limiter Stop mechanism
hope this helps ?
if not then u have some internal short or external short of the feed and exit Pwr. wires i have never seen or heard before cause your described symptoms above in detail ?
Thanks for that insight and the pictutes. I will give it a look this weekend.
I forgot about this so here is a follow-up.
When I checked this prior I was parked without the vehicle running. I'm assuming it was a voltage issue because with the truck started it works fine. Maybe not quite enough juice in the battery to do both at the same time...🍺
