Whatchu Workin' On?
We had a sick little guy yesterday :(, so we ended up not leaving town. It was a bummer, but I was consoled by the girls request to play in the garage. :)
.....then did some carpet cleaning today.
Gonna just keep going over this stuff again and again until that water coming out of the wet-vac turns a more pleasant color. :D
If it was warmer outside I would say take them to the car wash and blast them. I used my pressure washer in the driveway with laundry soap with pretty good results. Took a while to dry.
Will smell like a new truck when your done!
Yeah, thought about that too. This is the first time I've cleaned auto carpet like this and I was a bit concerned about all the felt padding on the underside. Wasn't sure how it would hold up to pressure washing. So, I cranked some tunes and put that little wet-vac through the paces. :D
That would be nice.
Thought you were talking about Kira and her sister :hillbilly:
Just learning this site for the first time. Your new rig looks great. Should be finished in no time with the girls help. I would like to be there on her maiden run.
I had found this by poking around but my menu does not show the Avatar option. Looked again after your post but it is not there. Maybe it only shows up for premium members.
Premium membership not required, think you have to post a minimum number of times?
On the tree run, my compressor would only make ~30psi. Luke said that I probably had a busted reed valve on my MV50. Good call:
MV50 problems?? Sounds like déjà vu...
https://forum.ih8mud.com/threads/stupid-mv50.796249/
Your reed isn't held down by a screw though, that's something new. Going to have to drill and tap it. Make sure you clearance the piston, if it doesn't already have a hole drilled in it from previous versions casting.
