What weight of oil for 97 with 206k?
*shrug* I run 5w30 conventional all year round in my 97 with 282k and no leaks. IMO synthetic is a benefit with tight tolerance, high heat or extended drain invervals. If you are changing every 3000 and aren't running forced induction it just feels like money wasted.
I am changing every 5K miles full synthetic
full synth mobil 1 high mileage 5w-30
wix 51515XP
change both every 5k at most
burns about a quart every 3k
Ran 20W50 in Central America w/o a problem, probably the right oil for that climate. But I think I was running 5W30 all the way from MN to Oaxaca and the truck didn't die, so...:meh:
I have a pretty bad RMS leak that I am just not up to fixing...all the others done. Hard to tell what is gone from leak or burned.
I went with Castrol High Mileage Blend 20/50 with Napa Gold Filter.
Thanks all
Previous owner used 10W40 and changed it every 5k, so I do the same. This is a 3FE, with nearly >350k on it and it still runs fine. Currently running the Castrol 10W40 synthetic and I'm pleased with it so far, not that I would trust "seat of the pants" improvements much anyway.
wix 51515XP
I was all about that filter and ran a couple, then eventually started noticing a startup rattle when it sits overnight.. I traced it to the drainback valve in the 51515XP not working correctly. Even switched to a brand new one. Let the truck sit overnight: bad rattle. Went to the small-case toyota filter: rattle gone.
Just another data point.
10W-40 (High Mileage Mobile One is a great choice)
