What have you done to your Land Cruiser this week?
Was there anything obviously wrong with your original one? Or was this just one of the last parts to check? We replaced my entire fuel system and while it reduced the fuel smell, it's still there, and I'm at a loss to find the culprit...
One of the male fuel grommets (don't know what else to call it..." Was broken off. Also found the fitting in the The center section on top of the fuel tank was loose with no type of sealant on it... Hope you find your problem...😎
@TheEngineer this is from ChatGPT if it has any value… you may get better results given you know the specifications of the truck
For the diesel long wheelbase Toyota Land Cruiser HJ47 with the 2H six cylinder diesel, these are the commonly accepted factory fluid capacities and types. There are small variations depending on year, transmission, and whether it is a Troopy or pickup body, but this will get you very close for normal service work.
Component
Fluid Type
Approx. Capacity
Engine oil (2H diesel)
15W-40 diesel oil (API CK-4/CJ-4 or similar)
10.5 to 11 L (11.1 to 11.6 qt) with filter
Cooling system
Toyota red coolant or equivalent 50/50
13 to 15 L
Manual transmission (H55F 5-speed)
GL-4 75W-90 gear oil
3.5 to 4.0 L
Transfer case
GL-4 or GL-5 75W-90
1.8 to 2.0 L
Front differential
GL-5 80W-90 or 75W-90
2.7 to 3.0 L
Rear differential
3.0 to 3.7 L
Steering box
Gear oil or chassis grease depending on rebuild/setup
Fill to level
Brake system
DOT 3 or DOT 4 brake fluid
About 0.7 L for flush
Clutch hydraulic system
DOT 3 or DOT 4
Small amount
Fuel tank
Diesel
Usually 90 L factory main tank
Wheel bearing grease
High-temp wheel bearing grease
As needed
A couple of important Land Cruiser caveats from the “old iron survives forever” department 🛠️:
  • The H55F transmission prefers GL-4, not aggressive GL-5, because GL-5 can be harsh on yellow metals in synchros.
  • Many HJ47s have aftermarket auxiliary tanks, PTO winches, or swapped axles, which can change differential and transfer capacities.
  • The 2H diesel holds a lot of oil by modern standards because it is basically a cast-iron locomotive wearing a Toyota badge. 🚂
The HJ47 was the later 40-series diesel using the 4.0L 2H engine.
@the engineer this is from ChatGPT if it has any value… you may get better results given you know the specifications of the truck
Component
Fluid Type
Approx. Capacity
Cooling system
13 to 15 L
3.5 to 4.0 L
Transfer case
GL-4 or GL-5 75W-90
1.8 to 2.0 L
Front differential
2.7 to 3.0 L
Rear differential
3.0 to 3.7 L
Steering box
Fill to level
Brake system
DOT 3 or DOT 4
Small amount
Fuel tank
Diesel
As needed
This is a good place to start, thank you! Some of the fluids match from my searching but the amounts seem high.
Component
Fluid Type
Approx. Capacity
Cooling system
13 to 15 L
3.5 to 4.0 L
Transfer case
GL-4 or GL-5 75W-90
1.8 to 2.0 L
Front differential
2.7 to 3.0 L
Rear differential
3.0 to 3.7 L
Steering box
Fill to level
Brake system
DOT 3 or DOT 4
Small amount
Fuel tank
Diesel
As needed
In my giant stack of stuff I got with the truck I have found these. (I had the orange one already for my 84 60 series, but hopefully some of it applies this 84 hj47)
And on page 11 of the Gregory’s manual we get this.
If anyone needs scans of specific pages, feel free to reach out.
I was installing my driver side rear barn door and noticed a decent size gap between the body and door. The passenger side fits perfectly. Any help on identifying what’s going on would greatly be appreciated.
Can get additional pictures tomorrow when the sun is up if needed.
You install the hinges backwards? As in top on bottom? I forget but aren’t they different profiles on the hanger part of the hinge assembly?
Definitely the best day with the 40 I’ve had other than the day I got it. @Lifelong40Fan visited Asheville and somehow was able to convince his family that a total stranger needed a long help….which was true. He helped me change out the manifold gasket, set the valves, timing, and adjust the carb. I was a spectator for most of it. No vacuum leaks and when I say the 40 drives completely different…wow. Instead of 2,000 rpm it is now at 650. Sounds different, drives/shifts different….I can hear music. Thank you @Lifelong40Fan !!!
Love the chrome bezel!
So it is the hinges on drivers side that’s the problem. I ended up getting a set from a local member and had them painted because I felt like they were a little better condition than my original ones.
The passenger sides are fine and are the correct hinges, but for some reason the driver side isn’t. Probably for another year probably or another door on the cruiser. I’m just going to use the original on the drivers side.
In the photo, the one circled is the one I received from the member and it’s not laying flat where the original is.
My SuperBright cluster LED’s showed up so installed them. Decided while the smaller profile green LED’s do fit and work, it’s not enough light output for me so I went back to the original larger LED’s that are too long. Modified the “housing” dome scatter shield for lack of a word and made the room for them to be inserted easily. Dremel cut-off wheel took about 15 seconds
Also found that the SuperBright replacement socket twist lock has a greater electrical contact surface than the stock ones and fit perfectly. Anyway…I finally have my green LED illuminated dash cluster
Also repainted the gauge needles. That also only took about 90 seconds to do…why this project took me 4 hours to do is beyond me
View attachment 4141587View attachment 4141588View attachment 4141589View attachment 4141592View attachment 4141594
View attachment 4141603View attachment 4141605
If you’re ocd like me, that’s a normal amount of time to take 🤣 Love the results, great job.
@bernardbar3 I know EXACTLY what you mean…. I didn’t mention that I removed the dash cluster 4 different times including removing the speedometer cable, disconnecting the battery, clearing the base tabs and removing the ammeter leads…4 TIMES !!
Window cleaner on the inside of the dash cluster glass was tough with reflections coming from everywhere
What year is the rig? My rig is a 67
@mef0629 this one is a ‘75
