What have you done to your Land Cruiser this week?
What? You don’t like “phat bottomed girls”? 🤣
In all honesty, I’m running a thinner tire on the Steelies too. I like the taller “thinner” tire for East Coast follow the ruts adventures.
Let the tire preference bombardments begin…😳
Nobody likes boney chicken wings.
Or fat tires on FJ40's!
You know you're getting close when the air cleaner goes on! I got the throttle cable sized and hooked up and the fuel lines ran and pump mounted, along with most of the wiring with the exception of the fuel pump and coil wire. And the vac lines ran to booster and pcv vavle.
Need to swap out a brake light switch that was acting up.
Decided since I had the cluster out I would be able to reach the wiper switch.
Since I have a fiberglass body and the wiper switch needs to be grounded to allow the washer function to work I needed to pull the switch and add a ground. Been putting this off for a year or so.
I pulled the switch, took it apart,
drilled and then installed a small screw in the side to attach the ground. Works great now.
Upgraded fan clutch and fan, had to clearance fan with Dremel small amount to clear shroud... thanks @wngrog for documentation on this
Aisin fan part -(FN-T022)
Aisin fan clutch-(FCT-049) For 3f FJ80 Green Fan Clutch. Interesting to note original fan stamped 79 and new stamped 22
Spring under and 37s? Need details
Yep…it was SOA until a few months ago. I needed new springs and decided to try and go for a low SUA with 37s. The rear is SOA with a traction bar.
I’m going to trim the fenders similar to this guys trim line
More and more 300s around here where I live these days.
4” front springs?
Man I know there are tons of purists here. But I love a good built rig.
4” front springs?
Yeah, this was a rusted piece about 10 years ago that I’ve built over the years.
2.5” lift springs
1” longer than stock shackles
4 degree shims
Lowered bump stops
Lots of cutting to come for the front. The rear is already trimmed to fit.
Getting the 37s balanced today to try and cure the death wobble
You may already know of or have done this but I ended up taking my ride to a local Toyota dealership for a ‘road-force’ balancing……. It made a significant difference! :cheers:
4” front springs?
I had 37's with a 4" SUA lift on my '73 about 10 years ago. Never drove it on the road. I was doing a SOA and thought I would try them just to see if they would fit.
Been waiting on my Walmart battery to give it up……. lasted 9 years! Decided on a Toyota TrueStart lifetime battery since I had a $25 coupon 🤑
I had a cleaned up tray ready to go and ended up pulling the mount to wire brush, prime and paint (kinda PITA to do)
Yeah, this first balance was to get it someone road worthy again. I think it’ll need road force balancing.
I did crank my 40 for the first time last night with the new efi, and it ran but poorly and had a much higher idle than expected or set. I don't have a video of it running, but I do have a fuel pressure test clip. After i got my new inline gauge put in. From what I understand about efi systems they shouldn't bleed pressure off like this or atleast no where near as fast. I hate how loud the pump is...but it is what it is for now. I know there are more quite options and an intank pump is in the works.
