What have you done to your 4x4 lately 2020?
Status
Not open for further replies.
Paint booth up....
@StucknKS and his coworker Jason that bought an 80 for his son and I put a lift in this weekend in near record time. 4 shocks, 2 bushings replaced and 4 springs in under 2 hours.
No time for pictures when your working that fast.
Haha. I thought about the pictures a little too late..:confused: I really appreciate everything @2fpower and @StucknKS !
Ready to start on something. Getting the shop cleaned up for spring.
look at all the room for activities.....
Take a selfie
learned something new.... I worked on three 80's last weekend, and found that when I worked on boost, when I jacked up one wheel, put transfer in Neutral, I could spin the hub. Tried the same on Lexi, and it would not, then Josh's truck and it still would not...
Ends up the answer is the viscous coupler is seized. here is a thread about getting rid of it.
Sliders arrived today for the taco. Got them primed and waiting...
TACO tuesday .... only it is on a Wednesday.... oh Krackle!!!
started installing my new seats in the 40
built an anti wrap bar for my front axle so I don't destroy another set of front springs
installed a replacement set of leaf springs which pushed my front axle forward and now have an 80 degree approach angle
A little fiberglass repair.
as well as a few other things I didn't take pics of such as reposition the steering wheel since the new seats are taller, fixing a leak in my oil pan, moving my winch fairlead
about time you work on your own rig!
The contacts on the bulb in the socket are probably loose. If it goes out again try to smack the dash above the panel to see if it comes back on or flickers. Mine did this quite a few times before I replaced all the bulbs with LEDs. A truck a did a front axle rebuild had the D light come on after I buttoned it all up.
Continuing on now working on lx450 built a custom drop bracket for the rear panhard bar to adjust for the lift
removed the caster correction bushings and switched to plates
Built a set of alignment fixtures found i was toe out instead of in
Status
