I spy cloth interiorYour drawer system looks really similar to the ones I built for mine a few years ago! Looks like a painted gravitex/raptor finish?
Props to your skills! Mine is by TrekBoxx, but looks incredibly similar.Your drawer system looks really similar to the ones I built for mine a few years ago! Looks like a painted gravitex/raptor finish?
SureSine 150 installed in original subwoofer location.
Access to Remote/Off/On switch & AC breaker through jack storage hatch. Looks like I missed a panel connector.
Yep, it's a JDM import in the UK. The cloth's great in hot and cold weather. Being JDM it also has AHC and tailgate mounted tyre which work great for our use case.I spy cloth interior![]()
Looks really good! New brake booster fluid reminds me of the movie Red Dawn. "Now get up there and piss in that radiator!". LOL!Well took a while and a small fortune but new brake booster, remanufacured rear calipers, rebuilt my front calipers. Seven or so bottles of Toyota DOT3. Did the techstream brake bleed and good for another 208kmiles!
^This, also I had the best luck getting at it through the driver's wheel well. Just remove the wheel and peel back the wheel well apron. Part I struggled w/ the most was threading the bracket bolt back in place.My thought is right before the oil change so that if any debris falls into the hole while replacing it, then it can hopefully flush out when I drain the oil.
yeah, thats the angle I took after lots of cussing and confusing tool combinations. good tip.^This, also I had the best luck getting at it through the driver's wheel well. Just remove the wheel and peel back the wheel well apron. Part I struggled w/ the most was threading the bracket bolt back in place.
Yep, it's a JDM import in the UK. The cloth's great in hot and cold weather....
Love mine! Where’d you put the mic? Also had to do Velcro on the box in the glove box to allow easier wire removal to reboot it. Problems resided after an update, though.
A year ago I pulled out my power steering reservoir and cleaned it. At the time I thought that looked good when I put it in. Blown away by the difference a brand new res makes… makes me want to whip out the credit card again.Looks really good! New brake booster fluid reminds me of the movie Red Dawn. "Now get up there and piss in that radiator!". LOL!
Looking good! With regard to the hangup issue as the stock tailgate gap cover impacts the new latches, consider this:Finished up the install of my Huracan tailgate storage. I opted to unwrap the loom so I can route the harness in the corner under the braces to keep it all clean and out of the way. I might cut out the brace on the left half so I have a little more room for the recovery rope to keep it in a bag in case it gets muddy from use. Otherwise, pretty satified.
View attachment 4067848View attachment 4067849
Soft shackles, dynamic recovery rope, ratchet straps, jumper cables, gloves, safety glasses, and spare coils all out of the way but quickly accessible.
Having isolated the sharp & small radius of the leading edge of the gap cover as the problem, I started searching for suitable edge protection solutions.
I ended up at McMaster Carr & found 2 options that fit, one semi-rigid & the other soft. Grow up!
I prefer the look of the soft & flexible strip, but think it will just get destroyed. I put the rigid strip on & it works really well. It is a very tight fit and no adhesive is required. It came in a 10 ft length that was tightly coils for shipping, so it still has a bit of a cast that I expect (hope!) will relax over time.
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
www.mcmaster.com![]()
Slippery Plastic Trim - 8271K13
I used the included seals. With care, they will sit down inside the carpet & on the metal. The round part of the latch faces the front of the truck and the bolts were tightened down previously secure the door against the underside of the lip of the cover.
Fine tune the fit of the latches and the amount of force required to lock them to your preference. I tightened everything quite a bit in the hopes of eliminating the possibility of rattles. Sounds good so far!
The front of the rounded part of the latch is a bit proud, and I did not fully...
Did I just cross post?!? I'm such a noob, sorry.
Do you know if the Slee mount will work withPenetration at rear left corner.
Second battery, compressor, & all wiring/fuses/relays here.
How long did install take? Looks great!Finally installed dissent rear bumper v3 with high crossmember and dual swing outs.
