What Happened...
supercarrera
Club Esprit de Four
Santa Clara, CA
Website
www.instagram.com
to my 76 FJ40 last night while driving down 280? Looks like the timing chain (I think it was a chain and not gears) or I threw a rod or something. Can anyone tell from the pic?
Yes that's the oil pan. The front of the vehicle is toward the top. That's the belt cover next to the damage.
something bad happened....it almost looks like a can opener got loose down there.
lunyou
What engine do you have in there? There's no chain in an F or 2F.
2F engine. Yeah it was knocking but not for very long.
Thanks for giving it to me straight Original. :-)
I was literally driving home after looking at a '94 80 I was thinking of buying. Now I guess I will. :-) I guess this guy got jealous and let me know it.
Is it possible to fix this without pulling the engine out? My brother in law mechanic says the engine has to be pulled to get to the crankshaft which will need to be turned or replaced.
Maybe this would be a good time to put in a chevy small block or even sell?
What would you guys do?
Ouch, If I could find a good cheap 2F I would drop another one in. If I could not find a 2F then I would consider a v8 swap or something else. Your BIL is wrong, you can pull the crank with the block in the truck just fine. I bet he just wants to get it on a bench and work on it as opposed to contorting himself under the rig. Will the BIL give you a break on labor or parts? If not, you may find you can purchase a crate motor for about what it will cost to rebuild your 2F.
Keep it 2f. I've got parts in Morgan Hill if you want to take a look; a whole 2f and a spare crank. The 2f is not ready to go or anything, but complete. I've been meaning to tear into it and take a look...
BTW, I'd take it out to work on it.
what are your options, how much do you want to spend?
v8 baby
Ideally I don't want to spend more than a couple thousand. Totally not sure what I'm gonna do yet. If I can fix it pretty easily by replacing parts, I may just do that. Otherwise, I may go for the v8 conversion. On the otherhand, if I end up getting the 94 fzj80 then I may try to sell it as is.
I would bet a weeks wages that there are very few good parts left in that motor.....for sure the crank and block ruined........
