what gas mileage is the cruiser capable of?
12mpg average would be good, your set up should be able to get 16-17mpg on the highway.
78 didn't have 3.70's........
hmmm, well...
frame number is 274768 indicating April of 1978 production
axle code is K052
I'm totally new to this, but I would like to know what I have so if you can shed some light, please do. Someone did tell me that 78s were all 4.11s, but not according to what i've read here.
i calculated about 8mpg city as well last time i checked, but thats with my F. you should be able to get a little better than that. in light of my new engine problems i'd imagine i'm getting more like 5mpg :rolleyes:
is it a canadian truck? if so they 40/55's got 3.7 starting in 75 I think.
I forget what KO52 is but it rings a bell 3.7's
SizzleChest said:
hmmm, well...
axle code is K052
SizzleChest said:
i know i'm waaay below what i should be getting right now (8 mpg city) but what can i shoot for? 1978 2F 3.70s and 32s.
It's pretty erratic, but currently, I am getting 14-16mpg
That's with a desmogged, performance tuned 2F with a header, non-usa distributor. bored over .030 with a 273 degree RV cam and oversized valves.
I also run an SM420, 4.11's lockright in the rear and 35" Goodyear Wrangler MT/R's.
I found that a new cap, rotor, plugs and wires (OEM, don't get anything else) and a quick scuffing of the points yielded my good results.
Also, as a side note, I am fiddling with the timing and carburation almost constantly. Keep that in mind.
I find that when I
When I neglect it, my mileage goes down to about 10-11mpg.
HTH
383 and 37's I get about 15 city and 18 highway with 4.11's (no overdrive tranny)
After hunting season the 4bt and 4spd auto are going in and hopefully my mpg goes up more.
I have a bone stock '78 40. Bone stock. 4.11's and 235's. I get between 13 and 16 MPG. I live at 5000' altitude. I am completely smogged, I redid my vacuum tubing and rebuilt mt air pump. I also adjusted my carb and tuned the ignition.
I am guessing you could do better, esp w/ 3.70's and 32's...
