What did you do with your truck today?
Goode said:
Spent five hours working on the oil pan gasket today. What a royal pain in the neck.. Will try to give it a go again tomorrow. Do I need to put a jack under the pan and try to press it on that way?
Sounds like you need an extra hand! I might be able to come by tomorrow for a couple hours and give you a hand. Ill call u
Readjusted my valves. 50 more horsepower! 30 MPG! For real it seams to be running better, like enough that I think maybe I fixed a vacuum leak I didn't quite know I had in the process. They seemed all a bit tight, across the board. Prev adjust was cold, when I put the head back on.
Spent five hours working on the oil pan gasket today. What a royal pain in the neck. (Literally) New gasket thickness makes it tough to get the bolts threaded. Managed to get longer bolts in to hold it in place but still unable to get it close enough to thread the pan bolts. The front and rear seals are causing the headache. One piece gasket. No troubles lining up the gasket, just can't get the front or rear close enough to get a pan bolt started.
First attempt was with the gasket tied to the pan. But that was impossible for me. Next, tied the gasket to the block and installed the pan. That helped a lot, but still a struggle. Will try to give it a go again tomorrow. Do I need to put a jack under the pan and try to press it on that way?
I have done about 8 of them so far. The best way I have figured out is that I coat the gasket with FIPG or your favorite rtv especially around the front and main journals and the corners. It helps keep the gasket from moving and helps seal around the ends. Its a pita but i push hard with one hand and start putting bolts in with the other starting in the middle on both sides. Then work my way around. Dont start on the ends. Once i get the bolts in I let it sit for a few hours or over night to let the FIPG to set up then I tq them down to the 17 inch pounds. I haven't had one leak yet using this method.
Got some new to me tires mounted up-
Before-
After-
4" ironman coming next-
Nice looking tires! ;)
Goode said:
Wrapped up the oil pan today.
Can't wait to see the " OLE GIRL" back on the trail!!!!
edgeatom said:
Poor boy fuel carrier with high jack swings out and off
Looking good Adam!
Hugh Heifer said:
Be kind. I have bronchitis.
Posted from a brick.
Be kind. My vag hurts :)
Goode said:
For the record, I have no idea what I'm doing.
Test fit...
Looks great!
This might be where that extra hex plug goes...
Looking good Kevin... I mean Andy
