Working on Matt's Hundy. Went to replace ex man gaskets & found the real reason it was leaking!
Good luck with thatDropped the oil pan for new gasket.
Goode said:Dropped the oil pan for new gasket.
Goode said:I went with two years. Is that too long or just long enough? You be the judge.![]()
Hugh Heifer said:Holy Christ on a bike...
ABS computer is bad in Penny. $1500 for the part.![]()
Apparently the OEM water pump that was replaced 4000 miles ago is bad too.![]()
What? Did you put it on or the PO? Sucks about the ABS. Hope you get it sorted.
Sent from another Galaxy
Mr. T in New Bern, NC. But, after some discussion with ACC, they took a closer look and decided they saw something during the inspection process that made it suspect. It also led then to believe the timing belt had not been done. Further inspection resulted in changing the earlier diagnosis and the water pump has been given a clean bill of health. It had been changed in April with the timing belt and all the idlers and stuff. (I guess that is why it is called an estimate! Which usually get worse, in my case it got considerably better.)
If I was not going to depend on the truck as a DD in a foreign country, I would have been tempted to try to get a used abs comp from a parts truck.
Posted from a brick.
