Went Christmas tree hunting as well.
when you finally give up and decide to destroy something, here's what an hour with a sledgehammer will do to a pinion shaft (and no, the bearing still won't come off)![]()
What on earth did you do to this poor pinion? OUch! I'm sorry, but this "ih8nitrogears" in your signature has gone too far, and is completely invalid. This is clearly an installer issue and some serious abuse with a BFH. I cannot beleive that you would wrongfully bash a good product in such a way. I've been on here for a long time, done over 5,000 diffs myself (not 3), overseen 40,000 or so setups, and sold THOUSANDS of Nitro gears for landcruisers. I urge you to contact me directly to come up with a solution to the difficulties you are experiencing, before blaming the parts. I am confident that many members (and vendors) will agree with our company's quality and integrity. Please contact me and we can find out what went wrong here.
or less variety:
battery install ends up taking a little more effort and cable reloacting, but all went smoothly.
a hot chocolate break with the 4 year old, I installed a Superwinch X9 on my 80's Slee Shortbus. It fits well, but I am having to fabricate a mount for the solenoid box before I wire everything up, so there is still more to do. I hope to post a detailed write-up and pictures on the install soon.I've always wanted to try this in my other car... Tried it here on my 80. Didn't look too bad... I'll continue working on the other panels...
It'll be cleaner next time. These vinyl sticks great!
Where are these from? Do they peel / scratch / get damaged easily?
Razorbackcruiser said:Picked up the family Christmas tree.
i've never had to use a press after freezing a pinion and heating a bearing to get the bearings on. we did with these gears, both of them. after heating a bearing, it should fall onto the pinion. same is true with freezing the pinion.
davegonz - i was originally using a bearing splitter, with a small press. on the rear, which was done a couple months ago, i took it to work to use the 100k press because my cheap press wasn't handling it. again,
our gear guy at work had to press the bearing on the rear after cooking it in the "oven". but i guess i don't know what i'm talking about since i've only done 3 sets (not three diffs, three pairs of diffs) before these. i just got lucky when the bearings fell on after being cooked. it was magic that the flanges didn't have to be "tapped" onto the splines and that the outer bearings didn't need a six foot cheater pipe to seat the bearings and crush the crushsleeve. apparently the guys in our shop also don't know what they're talking about since they probably haven't built a diff every single day for seven days for fourteen years.
Schnieb - glad they perform well, but curious if you also had tolerance issues when building the gearsets?
