That probably depends on how many people have asked him the difference between a Land Cruiser and a Land Rover that day.
Brave man putting all your trust in that bottle jack.I recently replaced my starter. The long span into the wheel well felt civilized and saved knuckles—the pinnacle of my mechanical aptitude. View attachment 3516351View attachment 3516352
That is one mighty socket extension, I hope it worked. I need one for just that situation.I recently replaced my starter. The long span into the wheel well felt civilized and saved knuckles—the pinnacle of my mechanical aptitude. View attachment 3516351View attachment 3516352
Nice before and after pics...those look so nice! What sliders do you have? Merry Christmas!!Installed rear flare caps from @solvefunction on the 80’s.
View attachment 3515386View attachment 3515376View attachment 3515383
Merry Xmas to you too!Nice before and after pics...those look so nice! What sliders do you have? Merry Christmas!!
My HDJ got an unwanted present for Christmas. Not sure what it was, but it very nearly.came through the windshield. Glass shards all over the passengers seat. Good thing I know a glass guy.
On the positive side I'll get to inspect the windshield frame.
It richoceted and hit the windfairing under the rack and knocked the paint off.
It was raining so i didnt see anything, but thought someone shot at me.
Have you tried something like a brass hammer on that mounting stud? After the penetrating oil and some heat, the vibration from the hammer taps should help get the oil to penetrate deeper and also be able to shake loose some of the remaining corrosion bond. Brass being the key since it is softer than the metal and shouldn't affect the geometry that the stud has (aka damage what a BFH would do), but as always don't get all barbaric. Oil, heat, some loving taps (repeat a decent amount of times) and she will come out with the extractor.All,
the rear suspension bushings have all been replaced. The HF press did its job and despite constant adjustments for lining everything up correctly, it worked great. All control arms are reinstalled and everything just has to be torqued to spec per the FSM.
Sadly, the broken off bolt just doesn’t want to come out. I drilled all the way through the bolt (breaking several drill bits due to lack of experience) and the extractor tightens up on the bolt just fine. Except, the bolt won’t budge. Nada, nothing, zilch. I have used penetrating lube and finally broke down a bought a propane torch and applied heat. It still won’t budge. I am hesitant to use an impact drill on it as if something were to snap off inside the drilled hole, I would be screwed harder than a virgin on his or her wedding night but NOT in a good way. Not sure what else I can do. Any suggestions would be most welcome. It’s the bolt that fastens the bottom of the shock absorber to the axle. Thanks.
All,
