What did you do with your 60 this weekend?
Brembo red, as in motorcycle brake calipers?
Looks really good.
I might need to do something similar.
Looks really good.
If you have a local powder coating shop, try something like RAL 3020, RAL 3001, or RAL 3002. That is from bright to less bright red. Any shop will know those color codes. The parts in your pic should run about $100 ish to do methinks
First test run of the new lift. My 60 got the nod for the trial. Works great, just have to build the courage to work under there. My shop is tiny but it will still help having a lift.
Got the 60 out to one of my favorite places, couldnt have asked for a nicer day! Here's a couple of shots and panoramas from the day.
Mom and Dad came to visit and my dad was happy to help out with sorting out and helping Finnish up the carb time and knuckle rebuild.
Diffs have been swapped out to 4.10s and everything seems to be running great!
Got the cleaning fever and wire wheeled everything I could and have it all a new coat of paint.
May even get some new tires roday ...33s or 35s... that's the question
@chichiflys yeah and actually the kit was already on the truck and after looking up the part numbers I found out it was a mojave lift kit from MAF this is from my understanding essentially the same thing.
Old Man Emu/ Man-A-Fre FJ60 4-inch Suspension w/ Shackle Reversal Kit
Looks similer to the 40 version but not sure if it is actually the same
OK thanks - I put one on my '78 FJ40 back in the day and it seemed to really make the truck drive/ride better. Of course it didn't have power steering, so it needed all it could get.
Well I flew into town and met my 84 for the first time. I replaced the cap, rotor, and plugs. I spent a while discovering the coolant temp sensor in the head and repairing the gage wire to discover that the gage still isn't working. Discovered I need a gas cap too. But really psyched to have found a super clean rust free solid unmolested 60.
Replaced Engine oil and filter. Topped up brake, clutch and checked steering fluid. Checked belt condition and tensions. Swapped out all 8 fill and drain plugs on diffs Gbox & Tbox to 10mm hex key plugs with magnets and refilled them all with fresh oil then changed the air filter. Today the plan is to drain and flush the coolant and refill with Toyota Red. Then change the fuel filter and get the grease gun out then replace the windshield wipers.
Should then be good for another 5000 miles
Did some rock-hounding near the Salton Sea (for metavolcanic called "Wonderstone") and Myer Valley in Imperial County (Petrified wood).
After loading the vehicle with probably about 1000 lbs of rock, the suspension was noticeably lower in the rear. If that's what it takes to get the Dobinson suspension/lift to get broken in, so be it! Dobinson makes a fine product.
