knocked the icecicles off the black Pig
No, really, there are icecicles hanging off all the pigs. It is cold here.
I brought her home an fzj80 e locking full floater![]()
Hey Lambcrusher,
Where's the e-locker going in, the Flatbed?
With that e locker can you engage it at speed? Is it wider? And, don't want to be goche, but what does something like that run?
I would not want to hit the switch while en route....I want it to be there when I need it. it is 7" wider than stock pig rear, 6" wider than the stock front. I tried to negotiate further, but parted with seven. full floating complete with locking diff and within an hour of my house. all break parts but the e brake cable, upper links( I forgot to pick up the lowers, but they were there-not going that route)sway bar and all its links and all the merry hours of cutting and grinding off the bracketry that will not be used(prolly about 30 pounds worth)I think it was fair.
could one put in just the dif and run the 55 or 60 housing?
yep. thinking about how to spring it... thinking about whether or not to have it narrowed to match the front track and run full custom short side, or narrow by 4 7/8" to run the 40-55 FF short side shaft and 1" spacers in front, or just run wide and get some 3" front spacers.....
I run a 80 rear and a stock front with an 80 third. I originally had a 60 series short axle, but upgraded to the longfield long spline when I went to chrome 30s. I run 1.5 spacers on the front.
missrenaissance said:And tips/tricks for getting the bolts out of the rubber bushings without destroying anything?
I'm just running the front narrower. 60 axle would be nice since I linked it. I'm not a big fan of out boarded leafs. Ideally the rear would be narrower to track around tight spots better, but that's not how it worked out.
tucker74 said:Air-chisel on the end of the bolt, it will drive them right out. Did you figure out your arms? I was 1200 miles away from my pig :-(
Tucker
