What Did You Do To Your Diesel Today (WDYDTYDT)
Wrapped up the balance shaft delete and timing belt install on the 2.0L TDI, pretty much ready to install at this point. If all goes well the engine will be in the Prado by the end of next week.
ALH oil pump and sprocket:
New chain, tensioner and windage tray:
Timing belt on, torquing crank bolt:
Timing covers and ALH oil pan installed:
Keeping the Bs buzzing.
Question for the brain trust, I'm doing a full preventive overhaul on the BJs 13B-T coolant system. The upper and lower coolant housings look good but have a few pits after cleanup. Planning to fill and smooth with some devcon.
Would it be worthwhile to coat those outlet areas with alodine or some other treatment prior to reinstalling and attaching the coolant hoses?
Built a transmission crossmember, motor mounts and finally got the engine installed in the engine bay. Really liking how things are fitting, the engine bay layout looks like it will be much better with the new TDI than it was with the old one.
You guys ever hear that small, quiet voice in the back of your head that says “don’t come up with a new project until you finish at least one of the other ones? “
I’m really good at ignoring that.
View attachment 4107435View attachment 4107436View attachment 4107437View attachment 4107438
That 15BFT (?) is gonna rip in the quiet voice in your head. Did it come with the 40 or was it one from @AlbertoSD
At least you listen to the voice, where as I, ignore it and regret ignoring for donkey years 🤣🍻
It was a separate bad decision, and it came from @T-ridecruiser! I helped (I mean mostly watched!) Alberto shoehorn one into his BJ42.
This will be fun as it will be on an 80 frame and will be a dedicated trail rig.
15BFT/h55/3:1 t case/Blackbox/37s.
edit: the 15BFT came from @T-ridecruiser….the bad decision was all my own!!! I didn’t want to sound like I got coerced into this!
I vapor honed some parts today. It’s extremely satisfying.
I’m doing it at @aljollano ’s shop. We split the cost of a VHT machine. A.J. lets me come up and make noise sometimes.
I saw something amazing at the Carolina Relic Run last weekend: A 40 series powered by a 3 cylinder Detroit Diesel.
Really an amazing machine.
There is just so much that has gone into this 40 it is hard to describe.
In addition to air brakes, it has a conventional two circuit boosted hydraulic braking system--behind the seat.
And just to justify posting here, my son and I took the diesel pickup and the Omani diesel 80 to the meet and had an absolute blast!
That is the Omani in the center there. The organizers did us the honor of selecting the Omani to represent all 80's in the meet's model lineup, for which we are quite grateful
Got up at 4 AM and reported to work in Stockton/Valley Hybrids. @orangefj45 greeted me with a hug and I had the honor of working with the team on swapping a 1HZ/R151 with a 1HDFT that I rebuilt with a new H152 into a LHD 105. In the 100 series the cross piece that houses the hood latch does NOT come out so it was a PITA putting the new engine in. Finally succeeded but the input shaft of the transfer case from the R151 is different then H152 so Georg will address this in the next few days. The 105 came from Saudia and I puke when I see the wiring. As an example I put the battery connection. Some of the wires are twisted by hand with no insulation.
I use crimped Panduit heavy duty lugs that are used in diesel locomotives. You can buy them on Mouser electronics.
View attachment 4126866View attachment 4126867View attachment 4126868View attachment 4126869View attachment 4126870
Always great spending time with you Ofer!!!
Georg @ Valley Hybrids & Terrain Tamer
At the moment the guys in Dubai are wrestling with our own little tranny dilema.
Mister Blue the 105 came with an R151 which I lived with for a couple of years after putting in an 1HD-T. But after a ride in sand I destroyed the washer in front of 1st gear and it started popping out of 1st at inconvenient moments so we are putting in an H151 with taller 2nd and 5th installed. And we are learning about the rear mounted gear shift needed for the 105 with split front seats. This one caught me unawares. The repaired R151 is back in Mr. Blue for the moment while we try to get the right set of parts or housing or whatever for the H series components.
I, meanwhile am in Northern Virginia trying to 'help' remotely.
Georg, for me to be allowed to work in the shop with your amazing crew, it's an honor. I learn from each one of them every time I'm there. And it fantastic to have you as a friend! Cheers mate !
i missed that one! video is private.
Well I -think- I have remotely procured an H151 and transfer case suitable for Mr. Blue the 105 with the 1HD-T to replace the R151 currently in it.
One of the guys in Sharjah that I have done business with for year, and whom I now count as a friend, had a 100 series H151 that was pretty greasy but all there:
Prices have gone way up since the start of the recent unpleasantness in the region, but I decided to move forward with it, and I arranged payment and my friend arranged transport to PowerTec in Jebel Ali. The guys at PowerTec have now done a little cleaning on it.
It all seems to be there and we will be breaking it down to put the taller 2nd and 5th we already installed in the 80 Series H151.
I actually need two of these things, the second being for the Schrodinger 105 project, but we are starting with one to make sure everything fits in the 105 just right.
It is a bit hard to do this stuff remotely but right now that is the only option.
John,
Based on the 105 we got from Saudia, I can say that the mechanics in the Arabian peninsula are competing with the ones in South America. :)
