70 series diesel trucks also have a ground from the bell housing to the frame, in addition to the ones you mentioned. And, I added a small jumper from the radiator to the front bib.
I’ve had good results from using the largest diameter (smallest gauge like 0 to 0000 AWG) pure copper (not copper plated aluminum) braided welding cable for battery & starter cables. The larger the cable, the less resistance and the more amperage flows to the starter. It makes a very noticeable difference in how fast the starter turns over vs. the puny factory cables.Was able to get the 2H stated with a local
Club members help. A jumper attached to the starter and it fired up immediately. Going to start looking into making my own cables and adding another ground.
Previous owner had the engine ground attached to aluminum and a much smaller ground to the frame. Going to redo all of these and add another ground to the body.
I plan to convert to a manual cable for both my Hilux and my Dodge CumminsFor those of you with these old diesels, have you sourced a new/used EDIC motor? I’d love to have something OEM, but they’re $6-800 from what I’ve found. If I can’t find anything I’ll rig up something manual.
I see cable setups that route from the cab to the radiator and double back so the drive can pull the handle to turn off the car. I'm wondering why a rod that can be pushed isn't more popular.I plan to convert to a manual cable for both my Hilux and my Dodge Cummins
I will have to look closely at the setup, but to reverse direction all you usually need is a bellcrank and something/somewhere to attach it. Bellcranks can also be used to add leverage at the cost of travel.I see cable setups that route from the cab to the radiator and double back so the drive can pull the handle to turn off the car. I'm wondering why a rod that can be pushed isn't more popular.
I've also seen shoelaces through the grill so you have to get out and pull it.
