That's gonna leak.
My wife has a cricut machine which will cut a variety of material to a pattern/picture or diagram from the PC. First thing I thought was "wow I could make all my own gaskets from that".....when you need to rebuild the front axle and not all gasket are available at the dealer (pandemic delays ...) so DIY ...
In today’s politically correct environment, it’s referred to as “self lubricating”, not leaking.
How did you cut those?when you need to rebuild the front axle and not all gasket are available at the dealer (pandemic delays ...) so DIY ...
Disconnected the pto drive shaft from the winch so I could drill it out for a 1/4" shear pin (it was a 3/16")
Made new pin from mild steel.
Also installed some battery terminal covers.
With manual toolsHow did you cut those?
I have done some using the school's laser.
I have read how others installed high-strength bolts for the original shear pin.Keep in mind a sheer pin is meant to be the weak link in a PTO winch.
OEM upgrade
The Toyota OEM "upgraded" PTO winch shear pin is available from Vancouver. It is 5mm in diameter and of unknown hardness. If it shears off again - I will report back.
There is no way I could have been that steady with a knife.With manual tools
Olfa knife and a revolving punch plier...
the gasket 0.4 mm thinkness
I feel like you just pulled out a parasite....Removed what I'd believed to be an abandoned kill-switch that was above the door as I thought that would make a good spot to run my solar panel wire into the cab as there's already a hole there...it wasn't abandoned, there was a live 24v wire attached to it. traced it and pulled the whole thing out.
View attachment 2652799View attachment 2652805View attachment 2652812
That's the second of two kill-switches this thing had, along with steel wire-mesh screwed into the inside of the rear slider-windows...P.O. must have lived in a sketchy neighborhood.
Stoked to see some epic 'how you carry your bikes' and trailside shots from that trip! EnjoyInstalled a new 'saggy diaper' Trasharoo, my last one disintegrated due to UV. I'll have to remove this when not in use if I want it to last more than a year. Kinda of a PIA as there's not much room between the tire and the door.View attachment 2653617
Also loaded up my gear for a week of mountain biking in St. George and Sedona, taking the scenic route down U.S. 93 & 89, yellow ammo can is my groover just in case it's required where I camp and digging a hole in the red-rock and sand is sometimes not possible.
In all fairness, the snail is more aerodynamic.cross post, but seems fitting.
I miss the country, food and beer.Today I took the cruiser on a 300km tour around the Eifel national forest and Huertgenwald. Also visited the Roman aqueduct and Satzvey castle.
