I attempted to replace a bad O2 sensor today and sheared one of the mounting studs clean off the pipe. I am attempting to work on the other one more gently but TBH I was using a 1/4” socket to begin wi5 and barely put any toque on the one that broke so I’m not sure I can do too much to the other one before it too breaks. I’ve been soaking it every few hours with PB blaster and taking a torch to it but it’s not budged yet.
This leads me to the meat of my question. What would you do in this situation? My instinct is to take it to a shop, have them cut them off and weld on new studs. But I’m not sure if the labor required would end costing more than a new exhaust all together. That lead me in to thinking if doing so would be a good opportunity to have the sensors relocated to a spot that is a little less exposed to the elements and easier to reach for future me… and, well… then I thought I should probably poll the group to get input before I got carried away or reinvented the wheel.
So, in this case the exhaust is stock and all bolts and clamps on it are heavily HEAVILY corroded and unlikely to loosen without, at least a good fight. There are no leaks so it’s definitely useable but there’s no way to non-destructively pull the sensors or do any other service to it. Would you replace it with an aftermarket kit, have a shop replace the pipes or salvage the stock system?
