I have a 1979 FJ40 with a 2F engine with all the emission equipment still on the vehicle.
I was having an issue with a little smoke only at start-up and only until the FJ got warm. I was told that I also had a leaking manifold gasket. I decided to tackle both issues at the same time. I carefully removed the carburetor and set it aside, then the intake and exhaust manifolds, and finally the rocker arm assembly.
I took the manifolds to a respected machine shop to have them decked. While the manifolds were being worked on, I replaced the valve stem seals.
I used an air compressor to hold the valve up while I replaced the seal.
I put everything back together and started it up, and it immediately started smoking at various times, black and grey smoke. It smokes like a locomotive all the time. If that is not bad enough, it leaks a lot of oil from the joint where the EGR pipe connects to the bottom of the exhaust manifold. The EGR cooler is coated in oil. I can’t tell if it is just because of the oil running down the EGR pipe or if it is also leaking out of the EGR cooler.
I can smell oil at the exhaust.
If that isn’t bad enough, I’m now getting a significant amount of gas into the oil pan.
A friend took the Asian 2-barrel carburetor apart, cleaned and tuned it. We took it out for a 50-mile ride on Saturday, and the cruiser never started, idled, or ran better than it does right now, but it leaked or burned 2 quarts of oil during the 50-mile ride.
What could I have done to cause these problems?
Is it possible a defective mechanical fuel pump could be pushing gas directly into the engine?
I need your wisdom…………..
