- Joined
- Sep 21, 2014
- Threads
- 4
- Messages
- 360
Couple things happened today before getting pulled off. Disassembly time Rob posted was pretty spot on even being on your back.
Ohyeah man! Let the crawling beginView attachment 3743247
View attachment 3743248With Rob’s help pressing on gears and some encouragement from Alan. Got my low range gears all squared away and installed this morning.
To be clear “my encouragement “ was standing there with a YJ in my hand watchingView attachment 3743247
Test drive go ok?With Rob’s help pressing on gears and some encouragement from Alan. Got my low range gears all squared away and installed this morning.
Keep an eye on your speed sensor after reinstalling, mine started leaking. I had to install a new o-ring.With Rob’s help pressing on gears and some encouragement from Alan. Got my low range gears all squared away and installed this morning.
forum.ih8mud.com
landcruisergrilles.com
Headlight conversion 7” round
Conventional vs led isn't different on the wiring. I don't know what wiring harness he had supplied but if there is not a relay. You will always be running brights even when you are not trying to run them as the highbeams are triggered by ground and that will feed through the lowbeams. So there...forum.ih8mud.com
Very temped with this sale to buy the bucket and convert my 80 to round headlights. 7" round LEDs are everywhere and cheap...
80 series headlight housings only, fits with factory grille only.
ships bare metallandcruisergrilles.com
forum.ih8mud.com
Well, you did put it back together! lol.View attachment 3749747Got half of my interior back together yesterday. All that’s left is hooking up some power wires and putting the door cards back on. I’ll worry about the rest later. Also @Beach80 came over in the AM and helped me troubleshoot my CDL not engaging
Ruled out the CDL button on the dash as well as the relay and motor not working in the actuator.
With the tcase in neutral, pressing the CDL button actuates the motor and it audibly is moving but spinning one of the front tires confirms the CDL doesn’t engage.
Jumping the pins for the low range switch on the tcase, same thing. You can hear it actuate but no lock.
The CDL light on the dash does come on if you jump the pins for wire to the CDL activation switch on the tcase but not otherwise. Not really sure what the issue could be.
I think to start I need to replace the three button switches tcase to rule those out since they’re all super rusty and two of them have destroyed connectors. The top one is easy, the other two not so much without the tcase tilted down…
If those don’t fix it I assume the actuator needs to come out to see what’s going on
