What are you working on?
My oil pressure gauge has been reading a little funny. Checked the crank bolt for 304 ft lbs. check. Installed manual gauge. Bingo! Starts out at 60 psi. Drops to about 35 as warming up. Settles at about 25 after 30 min. Goes up with 2500-3000 rpms. Got a new Toyota sending unit coming.
When the batteries die, power goes out, Ice for the win to keep the cool refreshing Coors cold!
I picked up some trays and bags and am making my own ice blocks. No more milk jugs. Each block is about 7-8 lbs and this size will fit sideways in my coolers from 32qt and up. They come in several sizes.
What brand did you buy? I just bought a viper remote last week to install
I bought from Trail Teq out of Australia. It was plug and play. No alarm just keyless entry.
Looks like I’ll be buying that and returning what I have
After spending the summer throwing away stuff, finishing projects at the house, and trying to organize my other stuff, my garage is finally cleared enough to pull the 80 in and shut the door. Still have some straightening up to do but it fits with working room around it.
With the truck in the garage I did a thing to put on some new things.
One is not the same as the other......I see 37's in your future!
Shop organization! new toolbox thanks to my dad upgrading. Also changed a rotor and greased inner wheel bearing on the white cruiser.
Picture man, pictures!
Motivation to clean out the s***hole that is my shed
Cant recommend Smiley's Glass enough. Needed the windshield replaced on the white hundred and they found a decent amount of rust from a botched job last replacement (Ace glass in Richmond). Could have been really bad. Smiley's called and just said they needed an extra day to grind away the rust and prime the surface. Insurance covered but still only $380 total including the grinding and priming the metal!
Before...
After grinding...
