3-4 quarters and several pennieslet me know if you find ay quarters![]()
Vanity wins out!View attachment 4170956View attachment 4170957View attachment 4170958View attachment 4170959View attachment 4170960
I swapped the consoles from the old 100 to the new. I just like the OEM look better.
Gotta admit. That's a lot of work for a purely aesthetic result. Especially when's it 1234°f outside![]()
Oh my. Thats deep! Nice job you got this!Current condition of the 1KZ!
Recently got the Throttle Valve cable handled, dropping the valve body was interesting. The one bolt that holds the TV cable and wire harness brackets on the top of the transmission was just about the biggest SOB bolt Ive ever delt with. We ended up having to remove cross members and drive shafts to lower the trans/engine enough to squeeze up in there from below.
Need to get ahold of flex plate bolts, trans filter, egt probe kit, and the gasket between the throttle body and intake manifold.
Yea, I picked up a 5 gallon bucket of Fram 90 weight for $49. Still on saleAlright, so working on the install of the F&R diffs and ECGS recommends Lucas 85w-140 Non-synthetic gear oil for break-in and normal use. I was at Advance Auto Parts and saw that Fram 85w-140 gear oil, 5 Gallon, was on sale for $54 ( total Lucas around $120). I'm thinking of using the Fram for break-in and the switch to Lucas, and wanted to see if that's a good plan or if Lucas is that much better and should be used only.
Also, if I buy the 5-gallon Fram, someone else can use it for the break-in period.
Yep, that looks like $$$. I can not wait to see it at SASIn a previous thread I mentioned I don’t like money, so I bought a new air compressor and have been working on mounting it in my QPM. Need to clean up the wiring and wire in a solenoid to jump my starter battery from my house battery as a 3rd backup option. (Disclaimer - you shouldn’t jump a starter battery with a LiFePo battery)
This will finally allow me to run my fridge all the time without the key in the ignition and have some extra USB plugs throughout the truck. Still have a few other gizmos to think through.
