- Thread starter
- #61
My Dad came up this past weekend to help sort through all the electrical. He’s an electrical engineer so he’s the wizard in that regard. He found the PO had wrapped the fuse block with wire around each fuse holder to bypass all the fuses.
Today I took the transmission and t case to a friends shop. He has a hot water pressure washer so I blew as much as I could off. My pallet of parts came also last week. Spent some time painting stuff and welded up the battery mount that was cracked.
I still keep hitting road blocks. I was hoping to make alternator mount a reuse my H alternator but I gave up on that idea and ordered a $700 2H alternator
. So ordered the alternator bracket and having to get a water pump pulley too. Hopefully that is the end of the part chasing…oh yeah I need an exhaust flange to mount the Exhaust pipe.
Next up is rear main, pilot bearing, flywheel, clutch etc and mount transmission/tcase.
Goal is to have engine in the truck this weekend to mock up motor mounts.
Praying it goes smooth…I don’t believe in luck
