When I did my TDI, I did the head studs 1 at a time and didn't pull the head. I didn't do them right away either. But when I did, it needed them done. They work well on an ALH to keep the head seated. Just my .02
Solid feedback my bro, I’m thinking if it’s out I might as well…Another .02 worth of free opinion. The long game. If you think you’re going to upgrade later, (I know you will), do the head studs now while it’s sitting on your stand. I think you made the comment about how “easy it is” to work on the TDI while it’s out of the (a) vehicle.
My plan as well, pull the cover, one stud at a time…When I did my TDI, I did the head studs 1 at a time and didn't pull the head. I didn't do them right away either. But when I did, it needed them done. They work well on an ALH to keep the head seated. Just my .02
Words to live by.
I can delete the vacuum thing, but there’s a coolant port just below that on the block that extended the same length.Quick searching they make a vacuum pump delete kit for that very purpose. Basically a cut flat plate to cap it.
Says you'll just need some other vacuum system then for your brakes
I was thinking of doing a little trimming at the firewall. I’m going to pull the vacuum piece and is tall the block to see how much room I’ll actually need , I think. I’d rather not move the mounts because then I’ll be adjusting everything from shift levers to driveshafts.Move the engine mounts on frame or make plates for the motor mounts that moves engine forward 1" or pull the tunnel cover and make a recess in the firewall, looks like the tunnel cover lip may fit under the vacuum thingy, bottom of a coffee can & a hole saw should work. That hose nipple is gonna line up perfect with the firewall so thats a pickle, larger coffee can ?
