So I see from the posts that you have a SBC. Are you using a GM or Toyota alternator? If so, are you still using the original Toyota Voltage regulator? Just a suggestion, the next time you replace an alternator that uses an external voltage regulator have the shop or parts store check your voltage regulator also. I would suggest that you take both to an alternator shop (motor rebuild shop) and have them checked for proper function. If they tell you the regulator is bad, I would suggest that you replace the mechanical external voltage regulator with a solid state one.mdjohnsen said:My voltmeter keeps jumping back and forth really fast while driving with an occassional stop between 12-14v. It acts strange altogether. It sometimes reads at 8v. COuld this be a grounding issue?
Solid State Voltage Regulator
