Violent shaking down the road
Hagerstown MD
I drove the 40 out on the open road for the first time and filled up her tank at the station, Problem she started shaking so badly the top almost few off. I only have it sittting on the truck unbolted. Tires and wheel new and balanced, Piss poor alignment? the front spring pack was knocked out a wack a litle on the right, I have a bend relay rod, this stuff sound to be the likelt culpret?
do a search for death wobble. Oh I doubt this is your problem cause you have a really bad shake, but just because a tire company balances your tires doesn't mean they are balanced correctly. It happend to me. I changed out my front bearing to find out after rotating my tires helped. Went to the tire shop and they asked me who balanced these tires, and I said you guys. Acutally this happend two times on me on two diffrent vehicles and two diffrent companies at the same time.
I am in the same boat as you with the death wobble thing. I have rebalanced the tires, replaced knuckle bearings, replaced tierod ends, checked caster and adjusted alignment. Like Wes1977 search death wobble and it will lead you to the things that I have done. Good luck
Is this your idea of a joke?
You say that one of your springs is knocked out of whack and you have a bent relay rod and you wonder if those might be the problem? Uh, yeah, it's a place to start:doh:
Going down the road fast enough to get a wobble going with the top mot bolted on? Idiot, the wind could pick it up and send it sailing into a car behind you and you'd spend the rest of your life paying off your liability.
Honk, thanks for your wonderful insight on my character. I merely drove 1/2 mile at 25mph to the gas station with the top clamped via vise grip.
If I need anymore insight or insult I'll be sure and contact you directly so unless that happens please stick to the subject or FO.
Oh, gee. what is the problem here? That the truck wobbled, or that the top nearly flew off?
Does the post mention speed? BTW, 25 mph is plenty fast enough to take a loose top off.
Does the post mention vise-grips..No. Not that they would be a reliable way to hold a top on with a bump in the road, much less with a front end wobble.
Did you say something about character?
How big are the tires? What degree of caster do you have?
What have you done suspension-wise....longer shackles? Lift springs? SOA?
Have you checked wheel bearings, knuckle bearings?
Death wobble can be caused by any number of about 287 parts in the front end,
most related to the nut behind the wheel;)
A little more info and maybe we can narrow down the possibilities.:beer:
Ed
Honk are we getting into a FU/smartass thing or what? I'm not here to piss you or anyone else off, I would think the same should be extended. We can't punch each other through the screen, so lets just drop it and stick to the topic please. I like coming here to avoid people I have a low tolerance for, I would assume the same for you right? I'm not here to offend you, don't want to, don't need to, if you want to be a smart ass (maybe your not and I'm reading your post wrong and taking it too personally???) do it somewhere else.
To the topic at hand, I have multiple issues up front,
1 right spring pack out of wack a little
2 front shackles are fairly long (6.5") and bent inward from overtightening on the spring.
3 greased the bushings via zerks but bushings are probably wasted.
4 relay rod bent, tie rod slightly bent
5 steering cone had a fair amount of play, I rebuilt it last night- no visible signs of heavy wear noticable.
6 this truck is driving me crazy and nickle and diming me to death. everything has had to be replaced on the f'in thing. and I'm really losing my patience and ready for dynamite!!!
Best guess from me..... Your shackle lift has your caster all screwed up and unless you or the PO have installed caster correction shims you have one of the top reasons for death wobble right there.
You did not mention what size tires you have but the bigger they are, the more they exacerbate the problem.
Get a magnetic angle finder and measure your caster....first order of business.
Bought mine at Ace Hardware for $10 and there are many places to use it on a cruiser other than caster.
Honk is a good man. He was just calling attention to your string of uh, stupid things you did to place yourself and others at risk...not to mention the cruiser!
Gitch'a angle finder and take a reading and we'll help you figger this out!:beer:
Ed
take the top off if you are going to drive or bolt it down, not smart and honk was making a statement from the facts given. im in agreeance (if thats how you spell it)
replace rods, ditch the shackles and look for some new springs, i can round some front ones up for you if you cant find any.
i know this s*** gets pricey, believe me it is not a cheap rig to own and build.
we are all here to help, not a pissing match
" this truck is driving me crazy and nickle and diming me to death. everything has had to be replaced on the f'in thing. and I'm really losing my patience and ready for dynamite!!!"
Welcome to land cruiser ownership.
I new I was in for a PITA project but, first engine then, brakes, then rear end, then new seat mountings, now steering and suspension, I've done everything myself with a little help (lots from mud). I've truned practically everybolt on this thing and the body still looks like s***e (not done anything there yet!), I've been working hard 10-30hrs a week now for a while, started working on this last november. It seem like as soon as i reach the light at the end of the tunnel it goes out! I'm just frustrated and pissed, I'll get over it sooner or later I guess.
F-junker: As stated with the top bolt er down or taker off!
To stick to topic death wobble is your enemy. Ditch the shackle's for one, check your castor and fix the screwed springpack. That will give ya a good start. Replace any screwed steering components. Even with FJ60 steering I have the minor version of death wobble due to some worn out steering parts...they're getting replaced during the SOA :D.
As per your complaints about every bolt here's a good suggestion: Take a break. Cool down park it for a few weeks and you'll be itchin to keep workin on it.
I did and it's the best thing I ever did now I actually can do the SOA. The bodies on these things can be a real pain. It's one of the lowest priorities on my list.
Just think how much you're learnin'!
Mine has been an expensive education....had to repeat a few courses, too;)
Ed
Ed
Measure once, cut three times....:D
Is that why I'm on my 3rd engine?
Dave, I don't know what your excuse is, but I rode the short bus to LandCruiser Skool;) Still on it, actually.
Ed
Yes it's been almost as expensive as college, I won't comment on the return!
You beat me to it. This is sooooo true.
We ain't dealing with new vehicles here folks.
JR
