On a SUA truck?
I'm going to replace the stablilizer and take off the second one. Today I'm working on SS raingutters. I'm giving myself a much needed break on this frontend until next Wednesday when I get more parts in.
I'm taking that the caster angle should be 0 degrees?
FSM calls for 1* of + caster, but I have heard that with larger tires a little more is helpful. That is what the long shackles do. In essence they rotate the axle counterclockwise(looking from the driver's side) and the caster can go to negative.
Poser is right....you do need a FSM, saves you a lot of time and money.
Ed
The long shackles in the front of the axle rotate the axle in the WRONG direction for a better caster angle bud...the longer shackle in the front will help with pinion angle...not caster....hence the need for the thick end of the shim to be towards the front.
unless I am all wet with this s***.....
--loose spring pack and u-bolts!
Dave, I don't know what your excuse is, but I rode the short bus to LandCruiser SkoolStill on it, actually.
Ed
hope you can make it to Cruise Moab next year
