Violent shaking down the road
Could be your alignment from the bent tie rod, if you have too much toe in it will cause that, mine did the same thing when I slide back down a hill and my tie rod caught on a rock. Quick check, measure front of tires in the middle and back of tires in the middle, depends on a lot of factors but you should not have more than a 1/4 inch more on the back side as a good starting point.
Yes it's been almost as expensive as college, I won't comment on the return!
Because you rightly cannot, since you are not even close to completing your education, nor does it sound like your truck is in a position to be going down the road bud.
If you have noticed the obvious things and not done anything to repair them, then clearly you need to get back in class, and stop seeking instant gratification for the whole project, only to be let down by shortcomings from not completing the tasks.
Instead, look at what you have accomplished, and move forward from there. It seems that you have a checklist of things that need attention.(and if you do not, get a legal pad and a clip board and make one, and check them off when they are DONE) Fix them. You do not need to come out here and post up the things that you see are not correct, and get mad at people when they are pointing out the obvious.
Yes Land Cruisers are an expensive hobby/way of life. Perhaps a serious re-evaluation of your level of commitment is in order also, since if you are really into these trucks, you will find that it only gets more expensive and the investment in not only time but materials will increase.
Do any of the items that you posted up have anything to do with why your truck shakes? They certainly could, along with a plethora of other items, some as simple as how much air is in the front tires or the fact that it has sat for so long and could very well have flat-spotted the tires.
Stop focusing on the fact that you have not operated your truck, but rather, focus on EVERYTHING that will need attention before you can SAFELY do so.
Good luck!
-Steve
I new I was in for a PITA project but, first engine then, brakes, then rear end, then new seat mountings, now steering and suspension, I've done everything myself with a little help (lots from mud). I've truned practically everybolt on this thing and the body still looks like s***e (not done anything there yet!), I've been working hard 10-30hrs a week now for a while, started working on this last november. It seem like as soon as i reach the light at the end of the tunnel it goes out! I'm just frustrated and pissed, I'll get over it sooner or later I guess.
Man! you need a vacation.. don't go postal on us..
I'm on vacation, self employment, I got my walking papers on Sept. 11 of this year (kinda hard to forget that date huh?). I started my own consulting business, and well it's been a little slow but the junk has helped keep me very busy. I ripped off the top today and took off the rusted carcase remaining of the topsides and started making rear corner raingutters. They have turned out well, I'm scraping the material and headed to the metal shop and buying some SS. that s***e will be there for a while. then bonding the top with duramex, slapping on the fiberglass topsides and doors. should give me a break while I'm waiting on new shackles, bushings, u-bolt skidders, tierods,etc. I'll post up pics on a thread thanks for letting me vent off a little .
A BIG SORRY to HONK! It's been a rough couple of weeks, I shouldn't take things too seriously.-Junk
pics of ugly's front end
well you can see the relay rod bent up. the steering cone rebuild helped but I still see some movement in the arm. The splines looked ok, but that is not the first time I've had one go bad before, even on a low mileage corvette (x2), I'm determined to go with a saginaw conversion in the spring. Unitl then I'm going to make the best of it with what I have and can replace and keep with the conversion. I think that I can have the relay rod modied afterwards. i'm waiting on Bud right now to make me a set up. Seems like a good guy.
check ou those shackles... Think they should go huh? I'm at 6.5" eye to eye. the damn things have larger bolts on the springs and samller on the hangers; is that the norm? You can barley make out the knuckles, I will buy a leveler, should it go on top of the berf case? I'm at a loss trying to find a level spot to work on though which is a problem.
help me out here as to where to start first.
Shackles- who, where, what size would be good (tires are 285 75 r16)
u-bolt plates would prefer the skid style for the front, Downey, Mark? best price where?
Dampener- factory Oem, again best place and price.
Tierod ends recommendations- I was going to try napa. I can't see any play in them though.
Spring packs easy to fix? Is there a tech post I should go to? they are quite rusty and pitted I would like to clean them up and add new friction pads, where do I find them? should I POR the springs? or just flat blk rattle can em'?
Thanks again for keeping me on the path.
yeah it's kinda scary!!! compliments the aviatar big butt!!! OH s***TT!!!
Your shim is in backwards. The front differential is pointing up to much.
Shims look like they are fat end forward, just where they ought to be. I would still measure the caster to see what it is.
Bending the relay rod was done by the PO as a poor-man's high steer, probably.
F-Junk, have you been through the front axle with new knuckle bearings/seals/wheel bearings? The addition of the caster shims, did you do that or was that the PO?
Hang in there, it will be worth it.
Ed
I use this for stress relief--- http://www.abunawaf.com/mix/store2/mulakama.swf
Front suspension will not flex properly since the shackle bolt is over tightened, bending the shackle and smashing the spring bushings...
I don't think you need two steering stabilisers. I would remove the non stock (lower one). It also appears you have lift springs along with the oversize shackles. Even with what appears to be at least a 4 degree shim or greater installed correctly you may not have enough caster to make up for the springs and shackles.
I let my springs rust up pretty bad last winter. Parked the truck in the gravel, held a pan underneath, and poured motor oil all over each spring pack. Worked a charm for the short term.
x17 on the angle finder. Caster is important. And you can park the truck on any flat surface, doesn't have to be level. Measure the difference between the knuckle angle and the ground. You can use a long straight edge (2x4, plywood strip, heavy string stretched tight, whatever) to eliminate dips and humps on the ground.
ps - welcome back
good call Poser...being as that was one of the problems with my old lift i SHOULDA caught that but didn't. Loosen those shackles. If it is using something like lock washers get locknuts/nylock nuts instead so that you can keep no hard pressure on the bushings
tust me you need a check list. you'll fell like your atually getting stuff done.
I've loosened all bushings and greased them. I'll flex it out tomorrow and see if that helps. can someone provide me with a bit of advice on this caster angle? I know the shims need to be there but I'm foggy on what angle I need.
Wheel bearings have been done, the knuckle stuff I didn'y touch. the wipers and stuff, I cleaned the hell out of that stuff! I was concerned on the wheel bear torque. I did not use a scale to set the preload. Just did it old school feel. then troqued the outer nut as tight as I could get tit without disturbing the bearings. Toyota call for 90ftlbs. I don't know if I have that or not.
death shake
I had a cracked bracket on my steering stabilizer and that was my death shake.
I'm going to replace the stablilizer and take off the second one. Today I'm working on SS raingutters. I'm giving myself a much needed break on this frontend until next Wednesday when I get more parts in.
