Vicki bit the dust, mechanic says catastrophic engine failure, I am skeptical
Maine
Hi guys, been years since I have been on here. My 2000 Land cruiser has about 160K mile on it now and she has been a dream to drive these past 9 years. Today while driving on the highway the check engine light came on, I lost power, then the traction and VSC lights came on, then oil temp. Rolled to the shoulder and had AAA tow me. Mechanic says timing belt failed and quoted me on a new engine around $8K for for the job. They said it has an interference engine, but I am pretty sure it does not? Can you confirm? Timing belt is original. No loud noises or grinding when the event happened, just a burnt rubber smell under the hood. What should I do? Any insight from you guys would be most appreciated! -Jon
Toyota literature said it's an interference motor, but the 98-05 is not, confirmed by a few broken timing belts and no issues on Mud. Verify yourself that it's the belt and maybe consider another shop if they didn't do any further detective work to come to that conclusion.
Jump in the region specific club houses for Maine and see if there's a Land Cruiser specific shop that has recommendations here on mud. This current shop is short-arming it and defaulting to throwing a giant number at you.
Like everyone else already said, while technically an interference engine, it's most likely fine.
I mean, 26 years on the original belt, which is a maintenance item, is pretty impressive!
True, we need pics of this belt/peices when it comes out.
Consider getting an inexpensive borescope and check all cylinders including the valves if they got bent.
Or the best way is to remove the cylinder head and inspect the components, it's going to go through a thorough process anyway so might as well.
Thanks for all the feedback guys! I am going to talk to the shop today and let them know your input! Crossing my fingers and will keep you posted.
I'll see if I can provide!
quick search finds many threads, I echo the above with a different mechanic if they went straight to engine replacement
Thanks for the link! I like this mechanic but I have yet to speak to the owner. I think the tech that looked at it does not know what the owner knows... we shall see. Owner owns several crusiers, and baselined Vicki when I got her. Independent toyota specialist.
Too bad no one in Maine:-(
2000 2UZ is not an interference engine
do full timing belt job and get on with life
This is the dream. Will report back!
Quick update! Took the gamble and did the full timing belt service and I am so happy to report there is NO ENGINE DAMAGE! On the downside, they did find a whole bunch of other crap that needs to be addressed in order to pass inspection so its still going to be an $8K bill but I am so happy I did not have to go searching for a salvage replacement engine. Thanks again to everyone who chimed in!
I am curious, what did the 160k 2000 cruiser need for inspection to push a 6k bill? Figuring about 1500-2k was tbelt parts and labor. Leaky rack? Ball joints? Rotors & calipers?
Yay for non VVTI, and no SAIP.
Exhaust leak, A/C service, Brake Booster replacement(not inspection related), Power Steering service
for $6K??? Ship it to me and I'll do it for half that.
If you can't find a better shop you should probably sell the truck. They're still abusing you.
