Vent temps....heater on. Whatcha got?
Deep East Texas
Read here from time to time about folks complaining their heater is not working well (for one reason or another).
I don't live in an area of the country where it gets 'kill you cold', so I've never given it much thought.
But going to town today....I just happened to think about that. After 20 minutes of driving my coolant temp was 186° F. and my vent temp (blower on low) was reading about 156° F. (pretty toasty), ambient 38° F.
Wondering what the 'minimum' vent temp would be that would still feel 'warm' to you guys that live in colder climates? I guess if it's like 3 degrees outside...even 100 degrees from the vents would feel pretty good?
ANything above ambient helps. I spent nearly 10 years in Wyoming and I used to just block of the airflow to my radiator for 3-4 months every year.
Here today about 40 degrees now . Ultra Gauge says coolant is 185 and vent temps are about 170. Hot enuff that I can't keep my hand over the vent for more than a couple seconds.
Ugh I'm jealous
Going to flush my core for the 3rd time today.
Having a diesel, mine ranges from "barely above freezing" to "almost could be considered warm", especially if just idling. The forecasted highs of -20c in the next few days will make that even more apparent.
All I know is the 80 has pumped out the most heat and shortest time than any other vehicle I've owned.
I agree. My readings today were just sitting in the parking lot this A M waiting for TOOLS to show up
It does do well and the blower motor moves a good amount of air. It's the second most efficient heater of the vehicles I own.
I have a '70 model Bronco 1/2 Cab....so not much area to have to heat up. It has 3 temperature settings basically.
1. Hot
2. Too damn hot (turn it down or off)
3. Surface of the Sun hot.
1. Hot
Sounds like the heater in my old Heep. I drove year round with just a safari top above, and half hard doors with fabric uppers, and the heater in that thing would still run me out of the cab! Of course I live in NC so we don’t get many days where it’s iceberg cold!
Dang! -20c! That's fresh!
What are your coolant temps like? Sounds like you'd benefit from running a blind on the radiator
I don't have anything set up for measuring accurate coolant temperature. When idling in winter, the gauge will never climb past the bottom mark on the factory gauge. When idling in summer, it never gets up to running temperature either, but will sit just a hair over the bottom mark. Once driving, it goes right to the middle just like it does all summer.
Seems reasonable to me for a healthy coolant system so I've never looked into it.
Hah, sounds more like an oil pressure gauge than the temperature gauge. ;)
No, that doesn't sound normal (for summertime). Might check that T-stat.
^^^^^^^^ Expand for reply
I have 2 80's and on the same cold day the stock one will start up and get nice and toasty very quickly. The second one that I have "Mud Modified" with heavier CST in the fan, new radiator, turbo, heat exchanger with spal fan, removed second row heater, etc. Takes forever to get warm, is likely to only hit 182f and has balmy heater temps. I never worry about it overheating though. lol.
Ok, let me rephrase a bit. If the engine's been running already, it continues to idle at the middle mark. From a cold start, it's never idled up to hot, even in summer. That could also just mean that I've never let the truck just sit and idle in warm weather that long either. In the winter its idled for 20 minutes before without getting hot, but in our winters that's the case for most vehicles.
So hot that I have to block the footwell vent in order to coexist with my wife in the passenger seat. Even then, I wear a t-shirt and she a puffy coat. I'll get temps on the next trip to Telluride.
If I reread my overheating post from over two years ago I rethink worrying about my truck not producing enough heat. :flipoff2:
While we are on the subject, I have question for you guys that live in cold climates.
My Daughter is an 'RN' and is a Travel Nurse. Currently, she is in Denver, Colorado. Of course, being born and raised in Texas, she has no idea what REAL cold is (kill you cold).
What items (emergency items) should she keep in her truck for wintertime travel. I worry that if she were to break down (engine disabled) somewhere out of cell phone service or for an extended period (whatever the reason), that she needs to be able to stay warm and hydrated.
What do you guys carry or recommend? (blanket, sleeping bag, water, granola bars, other)?
She sent me a forecast for Denver (Christmas day) that predicts a wind chill factor below zero!
