vacuum line plugged?
East Vancouver, BC
my buddies pointed out to me a vacuum line that was plugged running from the intake manifold to the carb diaphram. the po had put a carb needle in the end of the hose, disconnected from the carb end. we tried pulling it out and reconnecting it, then started it up and it ran rough and sputtered. so we plugged it back up again and all is well. i've attached a couple pictures for visuals. we came to the conclusion that the po plugged the line because it was easier than fixing something, we just didn't know what needed to be fixed? is it as easy as getting a new carb diaphram?
It is the throttle positioner / choke breaker and is part of the emissions system. It was originally connected to the vacuum switching valve and is not normally connected to manifold vacuum. If you don't have to worry about emissions, you can simpley remove it, but any vacuum line to the manifold should be plugged.
That's the choke breaker (CB). There's a check valve, labeled VTV, that goes between that and your vacuum source, which is at the top of the carb. If you hook straight vacuum to it, then it's trying to open your choke.
Here are the diagrams for the 78 fed setup. I hope they are readable.
Here is a vacuum diagram for a '76 which is probably closer to a 77 than the 80s 2Fs. If you need the throttle positioner to pass emissions, it should be hooked up to the VSV. It has a dual purpose (at least on late 70s carbs) to hold the throttle open so the engine idles at about 1200 RPM at speeds above 15 MPH and it also pulls off the choke when manifold vacuum is high.
http://members.cox.net/cglabe1/Photos/vacuum.jpg
