For sure! They closed the gates on us at 9:00 pm sharp, so there was some planning involved on that project.
I always have the manifold on its easier to tape up
A carb flange to keep weld splatter grinding dust
out
use the accessory holes in the heads to mount your load leveller
I thought I would be the only one with that problem now a days
I actually use a lifting plate that bolts on to the carb flange
Rick, after all is said and done, keep in mind the only time the carburetor will be on a set angle, and the drive shaft flanges on a set angle is when the vehicle is parked- - -so chances are anything you do will not be a problem.
I usually weld in scab plates maybe 4 or 5" long along the frame were the mounts will end up. You may find there's a stk hole in the frame where the mount is supposed to be welded in. Using the hoist and sling will be helpful, but the weight of the engine,trans and t/case can be cumbersome. I try to locate the front mounts and heavily tack them in so they will hold the weight of the driveline. Then you can set the engine assembly in with the pucks and bolts, and support the trans with a jack. This way you can adjust the driveline angle and check the t/case angle in relation to the pinion, and how low the Trans hangs below the frame. 3 to 5 degrees is good, but compromises can be made. Currently my driveine angle is more than that since I went to center rear output and a centered rearend.
I thought long and hard about "modernizing" to a roller-block 350/TBI, which is the direction I'll likely go when this 283 finally dies, but, aside from leaking oil from every orifice it didn't smoke at all, and has compression around 155 across all cylinders - I couldn't justify getting rid of it just yet. Plus, it doesn't seem down on power, and I have a record from the PO showing that it may have received an RV cam at some point. Seems to me it was "back-yard" rebuilt at some point in the recent past.
I've seen the carb-flange crane mounts. I know they've been used a billion times over the years and are probably 100% safe, but still, the thought of holding 750lb of driveline via aluminum bolt holes makes me nervous. I always have a paper towel at a bare minimum over the lifter valley when I'm doing any work, so I think dropping it in without the intake will probably be alright.
Your vertical placement won't be as critical as your D/S -P/S placement. Run a string from front to back pinion flanges to line up your front to back driveline location. Your vertical placement is compensated with u-joints. I set the engine hight by centering the fan in the radiator and raised the tranny t/c as close to the tub without interface.
I actually swapped the 327 out because I didn't want to fight with the brackets to mount a power steering pump without the bolt holes in the heads
Your Downey bell housing is it the steel scatter can or a cast piece ?
..the issue in my case is the manifold likely won't be attached when I test fit the engine.
Bolt it up just for this one job. Cost: 10 mins. Save: Countless hours and that nagging feeling 'is it right??'
