US/Japan Spec Differences
Newport News, Virginia
I'm stationed in Japan and have a '93 FZJ80.
To make a long story short, I cannot drive the vehicle until I get a new right side headlight assembly. They don't have any new ones in Japan (as I understood him, due to production shortage), I can't find one in a junkyard and I can't wait the month or longer to send the assembly to mainland for repair.
Does anyone happen to know if there is a difference in specs between US and Japan make Land Cruisers? If not, I'm just going to priority ship the assembly off my 93 back in the states.
Negative. From what I see, the reflective housing was burnt (presumably from a blown light) which in turn causes the light to register as "dim" by whatever Japanese technology gauges the brightness of light coming off each headlight.
As a quick fix, I cut apart a white reflective belt and put the reflective material in the housing, covering up the burn area. I hope it adds just enough to be within limits on the inspection.
I also hope it's not a fire hazard, or Japanese inspectors read this between now and my inspection tomorrow morning...
I think JDM and US specs are different, for one big obvious reason, as cited here: European Japanese car headlights
The "JDM" headlamps are unsafe to use for the North American roadway, since the beam pattern is biased towards the left of the car. Traffic in Japan drives on the "wrong" side of the road, therefore the "JDM" headlights were designed to provide more light at their curbside of the road. The result of using these lights on North American roads is blinding the oncoming traffic (they will think you have your high beams on). The only safe upgrade for Japanese cars here in North America are European specification headlamps. Traffic in Europe (except Great Britain) drive on the right side of the road (like we do), therefore the headlamps used in their market are suitable for use here.
Aren't you concerned the belt might catch fire/melt? Couldn't you polish the crap out of the reflector? Or stick some shiny aluminum foil in there? Alternatively, could you just put a brighter headlight in there and hope they don't notice? Finally, someone asks a question I can answer - I may not be a great mechanic but I'm an excellent useless hack!
One more thought...the Canadians import lots of JDM Land Cruisers. Just guessing, but I think they need the headlights swapped as part of the import/certification process. Might be a pile of JDM headlights somewhere there? Do our Canadian members know any more about this or is it a dead end?
Wait this still blows my mind. There aren't any Land Cruiser headlights in Japan? Yes it might not be US spec but you're in Japan for a few years. Put the JDM headlight in and keep your UDM headlight for when you leave.
It seems your headlamp test is not a matter of bright/dimness but rather RHD beam patterns, low and high beams included. If so, you might be able to pass by adjusting your headlamp position but you'll likely need a garage/shop with equipment that can measure such.
Shaken/car inspection - GaijinPot Forums
I read the OP's post as indicating he has 2 Landcruisers -- a JDM in Okinawa and a US spec one in the US -- but it could be read differently.
Called Hockey stick!
RHD vs LHD beam pattern.
I have a set you can have if you pay for shipping.
Surely you can find a scrap yard in Japan....they ship containers of parts overseas.
Try Dave Steadman at japan4x4. He makes it real easy getting parts from Japan to US so I imagine being in Japan is even easier.
Check yahoo auctions in japan for used parts. You will find plenty!
From 95 1DH-FT engine became.
Rear brake support became larger. 15inch weels will not fit.
As I know in 95+ new option became - viscous clutch in transfer case.
Rear lower arms 95+ became thiner.
On FZ engine exaust 2nd part became under the frame, before was under.
